02x 6-speed transmission, matching rear diff, driveshaft, cross member, linkage, and 034 street density mount. Everything you need aside from the plastic shift box and shift ball to swap from a 5speed on a B6 A4. 150k on everything, shifts like butter still.
Complete engine minus ecu, ac compressor, and some plugs on the harness, including manifold and stock turbo. 150k, still ran great when pulled to do a 2.7t swap. Stock tune until a mild stage 1 the last 10k. Timing belt should be done before it's swapped, it's due in another 10k. Local pickup.
$400 for the trans/diff/driveshaft, $500 for the engine, local pickup from Hagerstown, MD.
