Results 1 to 9 of 9
    Aug 24 2016
    roseville
    REPOST - RPM rough at idle
    I am reposting the same thing due to no replies.. hopefully someone else will see it this time and reply.
    So I got my audi s4 b8.5 a couple months ago and i love it. Today i took it through the car wash and put it in Park while the car wash was doing its job. I noticed my idle started to jump ip and down from 650-1100. After i got out of the wash, i drove it around and it was driving fine. Then when i parked in front of my drive way again and put it in park. It started doing the same thing.. thats when i took the video. In the video, i rev the car 3 times. Other than that, the car is doing that by itself. After about 10 minutes of having the car off, i turned it back on and it stopped doing it. It drove fine, and even in park, it was fine.. could it have been the water? a leak? any ideas?
    Link to video..
    https://drive.google.com/open?id=0B3...3g4bnk3cERFcDg
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Link is broken.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Senior Member Three Rings Sick S4's Avatar
    Apr 14 2016
    Charlseton SC
    I have been experiencing this as well. Not as bad as yours though, mine will jump up to about 1100 RPM and then search between there and 850. Hasn't effected drivability and goes away after I drive it for a few minutes when I put it back into park.
    Aug 24 2016
    roseville
    Aug 24 2016
    roseville
    Quote Originally Posted by Sick S4 View Post
    I heard some bad things about it being the pistons or the coils.. so im just cautious. better safe than sorry
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    That's really weird...have you changed anything recently? Check your air filter and replace or clean if necessary. Unhook your battery for a few hours then reconnect to reset the Ecu and see if that helps.
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Seems like you got water in an electrical connector some where. Ecu,coils,maf,map,injecors
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Aug 24 2016
    roseville
    Quote Originally Posted by BlownOne View Post
    I got my timing chain tensioner replaced from the audi dealership, thats a pretty big job. other than that, no. I took it through that same car wash today and it didnt do anything to the car this time. I wonder if it was a misfire.
    When the audi techs were taking out the engine, i asked them to look out for anything else that needed replacing, and they said that everything was fine inside. So im not sure. Im new to Supercharged cars so im kinda lost haha
    Aug 24 2016
    roseville
    Im going to clean out my cia when i have a day free. And change my oil. havent done that since i got the car. (2k miles ago)
