Results 1 to 31 of 31
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! ECS Carbon Fiber Side Blades
    Upgrade your exterior styling with the ECS Carbon Fiber Side Blade Set. These side blades were engineered in-house and designed to completely replace the factory pieces while adding a more sporty appearance to your vehicle, that matches with the factory appeal of the B8/B8.5 S4.
    Our inspiration for these came from the earlier B6/B7 S-line door flares where they would flare out more towards the rear edge of each blade. Keeping the same style in mind, we carried those characteristics into the new ECS Carbon Fiber Side Blade Set. A look that will be sure to stand out from the rest and only available at ECS!
    Add some style
    Fits:
    Audi B8 S4 3.0T 2010-2016
    Jason
    Junior Member One Ring
    Aug 11 2016
    Orange County
    I was just talking about CF door blades yesterday.... ECS keep up the great work... these pieces are the
    Established Member Two Rings Chris4Reef's Avatar
    Feb 06 2013
    13 S4 15 A3
    Orlando, FL
    How do you install?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Chris4Reef View Post
    How do you install?
    These replace your factory side blades entirely. Simply remove your old set and install these with your existing hardware and you're done!
    Jason
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Do a front lip for the B8.5!
    Apr 05 2016
    Portland, OR
    Jason
    How simple is this process Jason?
    When I was plastidipping my side blades I decided to do it on the car because I heard they were difficult to remove.
    Geoff
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    ECS is on fire lately with the CF bits. Good stuff!
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by whiped View Post
    Process is simple it's just time consuming. The factory blades use adhesive to assist with mounting. This is ultimately the part that many say is "difficult" as it takes time to remove or break down the adhesive enough to peal it away from the rocker panel. Once you take care of the adhesive you slide the whole blade towards the rear of the car (about 1.5in) and then it can be removed. You'll likely need to use goo-gone or an adhesive remover to get the excess adhesive off the rocker panel. A hair dryer works well too to loosen things up. I've also used fishing line if you don't have access to a plastic pry tool.
    Pro tip: Try to avoid using any tools or methods that can scratch your paint.
    If you take your time you should have no problem.
    Jason
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Damn as an s5 owner I'm really jealous. You s4 guys get too much love.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Aug 04 2010
    Queenz/Westchester
    These may fit the s5. Iirc, stock s4 and s5 sideblades are interchangeable.
    Sent from my SM-G928V using Tapatalk
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Would be better if it was just a CF cap that went over the factory side blades IMO. Installing these sounds like a PITA...
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Silverbullet S4 View Post
    +1, a good cover would be cheaper and much easier to install.
    Geoff
    Oct 08 2015
    Quote Originally Posted by shonseb View Post
    Same part number?
    @ecstuning, can you confirm? I might finally put my fishing stuffs in use.
    Current: '18 M3 ZCP
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    These are sweet but I should probably get the caractere side skirts to go with my bumper. Can't decide which right now. Where are the carbon paddle shifters for the B8.5!?
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
    Feb 06 2013
    13 S4 15 A3
    Orlando, FL
    Jason, any time frame when a front lip will come out?
    2013 Prestige S4 | Roc Euro Intake | AWE 102mm black tip catback exhaust W/ Resonated DPs | HRE FF01 Tarmac 20 X 9 | Michelin PSS 255/30/20 | ECS CF Spoiler | ECS CF Rear Diffuser | ECS CF Side blades | ECS CF Mirror Caps | ECS CF Fog Grille Accents | ECS 2 Piece Rotors | Deval Front Lip | H&R Street Performance Coilovers | Eurocode AK | Eurocode F&R Sways + Endlinks | MRC Racing Titanium Stud Kit | CR-15 Upper Brace | 034 Trans mount | RS Grill | Blackout badges | 3M Gloss Black wrapped roof
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    $600
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Established Member Two Rings 300zx2g35's Avatar
    May 03 2016
    SoMD
    OSIR makes carbon caps that go directly over your existing blades but in all honesty they aren't that difficult to remove. Took me about 20min to get them off my car using 3m adhesive remover and a plastic scraper to remove the adhesive
    2021 Nardo Gray RS5
    2015 Allroad RS5
    2014 Matte Daytona Gray RS7
    1st B8.5 US Avant Conversion
    2014 B8.5 S4 Prestige Avant
    Nov 10 2014
    Apex, NC
    I swear this forum does the same thing over and over...
    AZ: man it would be cool if we had X product.. i can't wait..
    Manufacturer: Here is X Product .. you can buy it now..
    AZ: man this is too expensive .. it would be better if we do this instead.. its cheaper..
    I'm pretty sure ECS and other companies are not coming up with these product ideas without user input.. and when they get here nobody wants them and has a cheaper idea.. you guys gotta stop going into vendors thread and shitting on their new products.. soon nobody will make sh!t for you.. if you have a cheaper better alternative.. engineer it.. create a thread and show the forum what you have done
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    Quote Originally Posted by doug97gxe View Post
    x1000
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Veteran Member Four Rings NastyNogaro's Avatar
    Oct 31 2006
    2008 RS4 Exclusive/Premium
    Quote Originally Posted by Zach L View Post
    x1000
    I was going to say the same exact thing. Bunch of whiners. These cars were in the 60's new, bitching about $600 for an aesthetic mod? Enlaes would probably charge $2,000 for these. So how about spend $30 on 3M diNoc adhesive and just wrap your current side blades if you need to have carbon fiber all over your car?
    I'm not a buyer for these, as I don't see the point, but will definitely be scooping the diffuser / front lip when it's available
    "Fazz" | Interactive Web & Application Developer | ig: @turbofazz
    2007 911 Turbo 6MT
    2015 Nogaro S4 DSG - Sold
    2008 RS4 Exclusive/Premium - Sold
    2000 Nogaro S4 6MT - Sold
    Oct 02 2006
    Wadsworth,OH
    It's really not! Have you ever debadged a car before? It's literally the same concept. You let the adhesive remover do all the work, meaning let it soak in and break down the glue. Once you weaken the glue it comes right off. Slide the whole side blade back and you're done.
    Jason
    Nov 12 2015
    Here
    das ist reis...
    Mein ist grau
    Feb 06 2013
    13 S4 15 A3
    Orlando, FL
    Has anyone installed them yet? Looking for some pictures before I purchase
    Aug 29 2012
    I agree with you, however some people must be buying their stuff, because the B8 spoiler is back-ordered until Dec. 12th. I think ECS makes great products, and definitely takes input from consumers prior to making something. You're never going to be able to please everyone, but as long as the majority likes it, they'll make their money back.
    Oct 02 2006
    Wadsworth,OH
    We have!
    Jason
    Feb 06 2013
    13 S4 15 A3
    Orlando, FL
    Just installed the ECS carbon blades. Removing the stock blades was a But if you take your time it wasn't that bad. Only managed to break just one clip in the process. The new blades look great and overall pretty happy with the look and fitment. Trying to figure out how to upload images to show you guys.
    Oct 02 2006
    Wadsworth,OH
    Thanks for the order and feedback! Sorry to hear about the broken tab. Definitely post some pictures when you get a chance!
    Jason
    Nov 10 2014
    Apex, NC
    download tapatalk and connect to the forum then you can upload images with that
    Present:
    Feb 06 2013
    13 S4 15 A3
    Orlando, FL
    Oct 02 2006
    Wadsworth,OH
    Looking good!!
    Jason
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Sorry to bump this, but for those who've removed the stock blades, where are the adhesive points? Does it run the length of the blade? Can I use some floss or fishing line to break the seal?
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
