Hello everyone,
I am a long time reader of these forums from Russia (sorry for possibly quirky English, as it's not my native language). I'm an owner of a 2010 NA B8 with roughly 60k miles on the clock. The car is APR st.2+, motor+gearbox, and was mostly running fine to these days. Last year I used it extensively in autocross and track days, but in 2016 I had little spare for these activities so the car was used mostly as a grocery getter and for long distance cruising (450+ miles one way, 90-110 mph on cruise).
This was the case last weekend, when I was heading Moscow on a highway, feeling not very well because of flu, on cruise control, with my only desire being only to get home before the traffic jams start. 60 miles from the city, I've heard clunks from the tunnel, immediately turned on emergency lights and pulled over. I power cycled the car, read it out with VAS 5054a, getting some error codes typically responsible for mechatronic failure. I tried moving slowly, and heard the distinctive noise from the tunnel. I decided to not push my luck any further, and called a flatbed from Moscow to come and get me to the transmission shop.
It was really hard to believe that this had something to do with the gearbox, because the general consensus is that DL501 transmission is reliable in mechanical department, it's major quirks being the mechatronic failures. However, listening to the running car proved that the noise was coming from the tail end of the gearbox, where transfer case is residing. We removed the gearbox from the car and disassembled it for inspection, seeing quite an interesting thing:
The seventh gear got destroyed completely. If that was the second or third, I would have attributed it to autocrossing/trackdays and stage 2 power levels, but that is the gear used on highway on low load. Transmission shop guys say that this is the first case in their practice of DL501 failing so miserably. The situation is also strange because the hypoid gear oil level was perfect, there were no leaks on underside, and all the other mechanical components (Torsen transfer, front final drive, other gears, clutch basket) look perfectly okay. I have nothing to think of it other that I'm unlucky enough to have come by manufacturing defect which demonstrated itself on 60k mileage only.
What I try to achieve with this thread is to gain insight on how widespread is mechanical failure of DL501, and how true is the wide belief that mechatronic failure is the only thing to be afraid of. Please share your experience, and maybe insight on what may have lead to what we see on the pictures.
