Results 1 to 18 of 18
    Veteran Member Three Rings Mr.Tan's Avatar
    Sep 02 2014
    '01 GTI
    York, PA
    225/45/18 snow tire, OK?
    Just a simple question regarding snow tires. TireRack has the Blizzak WS80 listed for an alternative size of 225/45/18 instead of the "recommended" 245/40/18. I know a skinnier tire will cut through snow better, plus they're a good deal cheaper in the 225/45. Is it OK to run this on the S4 without issue? I never usually run a snow tire on my car (haven't on any i've owned) but my tires are wearing out, and i plan to get 19's for next spring/summer so I figured i'd put snow tires on the stock 18's and run a smaller size if possible.
    www.epautohaus.com for all your aftermarket performance parts, wheels & tires
    Veteran Member Four Rings The Fat Kid's Avatar
    Mar 10 2015
    New England
    Those are the exact tires I had on my winter setup; they definitely fit.
    Are you driving on a lot of snow, or usually just on cold, plowed roads? The WS80s are beasts in the snow and OK when it is ridiculously cold outside, but you might hate them in PA since you guys usually have less snow and warmer temps.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    As long as the weight and speed ratings are ok then you'll be good to go. I agree with The Fat Kid, those blizzacks are amazing in the snow/slush/ice but suck in the dry, i sold those and bought the Hankook I'Cept Evo2 W320, amazing tire in all conditions.
    Stage 1 more than you RS3
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    I run the same size using the yoko ice guard 52 and have had no issue
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    May 06 2015
    Minnesota
    I run this size as well with Michelin X-Ice tires. Traction is unbelievable in snow and ice. I do find the dry pavement handling is a lot more "squirmy" than my summer PSS but I honestly don't know if that is due to the narrow size or the winter characteristics of the tire. Most likely a little of both. Bottom line is that tire size works just fine for the winter.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Sep 02 2014
    '01 GTI
    York, PA
    glad to know the tire sizes will work,thanks for the clarifications!
    As far as conditions around here--- its kind of a 50/50 chance for weather. We got slammed with heavy snow last year at some points but it was fairly dry and alittle warmer later than usual. Plows always come at night so during the day it can be tricky. It does seem that we get a lot more ice and slush, which i always get stuck driving home in from work, and now I live at the top of a steep hill and drive the highway in the mornings so I want to be safe. (i take the highway in the morning and the city coming home due to traffic). Performance isn't necessary for me, i drive kind of boring most of the time. I just want to know i can get anywhere i need to and be reassured my tires will handle the condition if it gets shitty real quick (which it does here)
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    I'd double check the load rating, usually pretty limited selection in 225/45 with the correct load rating if I recall, might not be a big deal to you though. My A4 came with a lower index load rating tire on it and I didn't think much of it at the time since a few numbers this way or that is no different than a passenger being in the car etc. but I ended up blowing a belt in a Michelin PS Alpine.
    Nov 12 2015
    Here
    225/45/18 snow tire, perfect.
    Mein ist grau
    Sep 02 2014
    '01 GTI
    York, PA
    Quote Originally Posted by MacFady View Post
    i've never really taken into consideration load rating before. The WS80 in a 225/45 says that its load range is XL with a max load of 1,521 lbs per tire
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    That's the optional tire size on tire rack and what I run. Blizzak WS80.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    [QUOTE=Mr.Tan;11958016]i've never really taken into consideration load rating before. The WS80 in a 225/45 says that its load range is XL with a max load of 1,521 lbs per tire[/QUOTE xl is fine higher load rating than required
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Quote Originally Posted by Mr.Tan View Post
    They're worth buying, but you might not need the Blizzaks for a PA winter. I bought the newer Yokohamas last year and I couldn't be happier. I live in Cleveland, where the winters can either be relatively mild (last year) or insanely bad (forecasted for this year). The 2 bad snowfalls last year were like nothing...my car didn't even notice the foot of snow that fell in 4 hours while I was at my friends' place. I was driving out of their development with snow up to the grille and the car was driving like it was an 80F summer day. I went with 18" wheels and thinner tires, and I was extremely impressed.
    Just to note: Winter tires almost always have a lower top speed than the rest, no matter the performance level. I know you said you generally drive boring, but it's always good practice to set the Speed Limit Signal in the car. My winter tires are only rated to 116Mph, so I set it to 100Mph, just to be safe. I figured I wouldn't come close to it, but with the ability for these cars to pick up speed I hit it more than a few times passing someone on the highway. It's good to have something remind you that you're not running your PSS :)
    Here are the tires I run:
    http://www.tirerack.com/tires/tires....m=44TR8IG52CXL
    Sep 02 2014
    '01 GTI
    York, PA
    Quote Originally Posted by hotleadsingergu View Post
    I've been going back and fourth mostly because of how spotty winters can be here. My parents and most friends have always used blizzak's around here in past years, so thats kind of why i keep getting drawn to them. Last year we got hit with probably 30" of in 2 days from the one storm, then it kind of faded off and we really didn't get much else but ice and everything. The roads were total hell for about a week because there was no where to go with the snow and it was too cold to melt.... and they're saying this winter will be bad here too so i'm getting a bit over protected LOL. I also got a job promotion so its a bit more important for me to be getting to/from work in bad weather.
    I was stuck between the michelin x-ice xi3 and the blizzak originally
    I didn't know that about winter tires so i'll have to set the alarm for it. Speed does easily creep up in these cars. I don't flip the car around alot but i do have a heavy foot haha.
    Jun 21 2004
    mpls, mn
    "Blizzaks" is not descriptive. There are multiple models, and they are significantly different. If someone says Blizzaks would work well, they're not really helping.. it's a brand name not a model.
    Blizzak WS80 (and previous WS models) are studless winter tires, designed for ice and snow grip. These are much softer on the dry roads in trade off for the ice and snow performance. The outer 55% or so of the tread on these are the tube multicell compound. Once half worn, you should replace as the winter grippy rubber is gone.
    Blizzak LM001 (and previous LM models) are high performance winters. These are designed to handle winter conditions, but not sacrifice so much on the dry roads. The aren't near as good on ice as the WS series, but still better than a typical all season on ice. This category of tire (Performance Winter) typically is a good choice when someone lives in an area that does get snow, but most the time the roads are dry or wet.
    So I think based on what you're saying, you should lean toward the high performance winter tire category
    http://www.tirerack.com/tires/types/...t.jsp?perf=PPW
    Sep 02 2014
    '01 GTI
    York, PA
    Quote Originally Posted by jprice View Post
    i mentioned a few posts up & in my original post that i was looking at the WS80, i guess i assumed most people would have seen that. We get a majority more ice than we do accumulated snow most of the time, thats why i'm leaning more towards the WS80
    May 06 2015
    Minnesota
    If you are down to the X-Ice or the WS80 I don't think you could go wrong with either one. Perhaps the best approach is to go with the one you can get the best deal on. As I said earlier above, I run the X-Ice in Minnesota winters and they are awesome. Traction on snow and ice feels almost like dry pavement with these.
    2015 Mini Cooper S
    Jun 21 2004
    mpls, mn
    You definitely did :) ... I got this thread and another mixed up. Sorry for that rant here ;)
    I run the Nokian Hakka R2s, and love them. I'm in an area that gets ice for a long time, but also drive dry interstates almost every day in the winter.
    https://www.nokiantires.com/winter-t...kapeliitta-r2/
    Here's a recent test comparing several of the tires discussed here including WS80, Xi3, Hakka R2, Ice Guard
    http://www.caranddriver.com/features...ce-data-page-3
    Sep 02 2014
    '01 GTI
    York, PA
    LOL no worries.
    Seems like a lot of people run/like the hakka R2's on this forum. I looked them up and did some reading, it seems like they're super impressive and go well on ice and through all types of snow levels. Price is alittle more than the WS80 in same size, but i'd imagine its worth it? I dont want issues driving on dry roads and it seems like some people say the Ws80 gets alittle squirmy
