Results 1 to 4 of 4
    Veteran Member Three Rings 0396's Avatar
    Feb 10 2005
    L A
    2004 S4 Avant- Windshield Fluid Leak
    Avant partners, yesterday I noticed blue fluid on the garage floor. The blue fluid was in front of the tire on the passenger side, not to mention the low windshield fluid light on the dash.
    My question before I start removing everything to try to locate it. Has anyone else have experienced this issue?
    Is the culprit a simple connector / hose along the front edge of the radiator?
    Thanks in advance for your reply.
    0396
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    If it's on the passenger side, it is very likely caused by the headlight washer leaking. It can either be the connection/hose at the washer or the washer housing itself is cracked.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Feb 10 2005
    L A
    Thanks for responding. I was thinking of the headlight washer. But I've never used the headlights washer...never had to. If it is, sounds like the front bumper has to come off? Thanks again
    0396
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Yes the bumper has to come off to get to the line that's connected to the headlight washer.
    Sent from my Nexus 5 using Audizine mobile app
