Results 1 to 15 of 15
    Jan 11 2007
    Salt Lake City, Utah
    Engine Girdle/Bed Plate Experiences Thread
    With at least some options available for a few years now, is there anyone who is currently running the SRM, Rockcandy, or Britishturbo (if he ever sold any) girdle or bedplate? If you are personally running it (or are intimately familiar with the car running it), please share the following info, if you would:
    --GIRDLE INFO--
    Girdle/Bedplate Brand:
    Miles on the engine with girdle (at high hp):
    Power level (whp/wtq, please specify if actual dyno figures, calculated from logs, or estimated):
    Dyno Brand:
    Dyno Gear (3rd or 4th):
    Turbo(s):
    Boost psi:
    Fuel:
    Methanol Injection (Y/N):
    Tuner:
    Block Part Number (AE [early] or BF/BEL [late]):
    Engine Bore (2.7/2.8/3.0):
    Main Caps (stock/billet, brand):
    Fluidampr Crank Pulley (Y/N):
    Notes:
    --If engine failure--
    Miles to failure:
    Notes on failure location and circumstances:
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Jan 11 2007
    There's literally not a single person running the SRM girdle, more than 2 years after release?
    LOOKING FOR:
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    I will be running Rockcandy's girdle. He is in the process of finishing my motor(This is going in TiAL 770 car) so hopefully in few months the car will be on the road. I 100% trust him with building my motor and his product. He is also building me my 2.8 heads for my other S4 which will be having OEM RS6 turbos. Tuner for my car is going to be Jared at VLM Spec. Both people were picked from doing my due diligence and not because they were pick of the month.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Jan 11 2007
    Quote Originally Posted by Yuppie View Post
    I can personally attest to Marshall and Jared both being good people, and both are a good choice for the build
    Keep this thread in mind, and report back like a month after making big power and after having romped on it for a while
    LOOKING FOR:
    Oct 27 2011
    TOYS
    Philly Suburbs
    I have put about 5,000 miles on my motor at around 700 whp. I run the car through the gears at least 15 times a week (usually much more than that). I went to the track in July to see where my trap speed was at (to confirm the power) and I guess since the track is much sticker than the street, I seemed to overpower my AMD stage 3+. I have't had any slippage issues on the street though, even when launching hard and running through the gears.
    Here's a data point for you:
    Miles on the engine at 700whp: 5,000
    Power level (whp/wtq, please specify if actual dyno figures, calculated from logs, or estimated): 700whp, 600wtq (dyno in 3rd gear on a dynojet)
    Turbo(s): PTE6062 gen2
    Boost psi:30psi
    Fuel: E85
    Methanol Injection (Y/N): No
    Tuner: Philadot
    Block Part Number (AE [early] or BF/BEL [late]): BF
    Engine Bore (2.7/2.8/3.0): Stock
    Main Caps (stock/billet, brand): Stock
    Fluidampr Crank Pulley (Y/N): No
    Feb 14 2005
    Quote Originally Posted by jibberjive View Post
    Thank you. Both are great guys, honest and straightforward so it was no brainier. I am very lucky to have RedRocketS4 local to me as he is very knowledgeable and always helpful to make sure nothing dumb happens.
    I will definitely update once we have everything sorted and we put fun miles on it.
    Veteran Member Three Rings Cacti's Avatar
    Nov 10 2011
    MI
    What ever happened to the solo Motorsports car that had the srm girdle?
    I have marshals girdle just waiting on my tune from Jared and some odds and ends and then it will run... hopefully.
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Quote Originally Posted by Cacti View Post
    Are you referring to the hibiscus GT car? That's the only one I can think of that had a girdle installed
    I believe the owner of SMS, Jfonz, and the owner of the car had a falling out. Only picked up some pieces of what happened, but it lifted the fonz lifted the heads on a glory dyno pull awhile back, engine was rebuilt. Sat forever, owner said he felt that SMS was overcharging/doublecharging him for work and parts. So I believe now the car is being parted out. It's really a. Inner because I wanted to see that thing destroy everything. Was one of the fastest b5's in the states.
    Nov 10 2011
    MI
    Quote Originally Posted by Peter1.8t View Post
    Yea wasn't it a 2871 car. That's unfortunate though.
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    Boost psi:30psi
    Fuel: E85
    Tuner: Philadot
    what girdle/bed plate are you running Monty?
    2000 S4 - silver- RS4 OEM widebody racecar
    Veteran Member Four Rings zatch_303's Avatar
    Jun 13 2009
    Colorado
    Don't forget Eurospec has one as well guys.
    // 2001.5 Pearl White B5 S4 Sedan 6MT
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by slowrideBC View Post
    None. I have a stock bottom end with h beam rods.That's it for the bottom end.
    Dec 03 2009
    PNW, Washington
    Correct. Had really high hopes for that car. Hopefully he keeps it and just has another place finish it for him.
    Veteran Member Four Rings OMGHI's Avatar
    Mar 22 2011
    Tempe Az
    I have a eurospec girdle, I am really excited about this thread and I will post info hopefully soon !
    997 C2S AERO
    15 Lava Grey TDI Q7
    996 TURBO (SOLD
    997 GT3 (SOLD)
    HPA TURBO .:R32
    IY B5 RS4 (SOLD)
    2001 Avus Silver RS4 S (SOLD)
    01.5 Nogaro RS6BB Avant
    Feb 14 2005
    Picture of Marshall's (RockCandy) product.
