Results 1 to 9 of 9
    Active Member Two Rings Dedsec's Avatar
    Apr 06 2015
    Sweden
    Question Instrument Cluster on-bench wiring
    Could use some help with my spare cluster wiring.
    Bought one to play around with and am trying to connect it for some tests but am stuck at, its not fully booting up.
    I understand it can go deeper into software / datas than just connecting wires.
    Basically what I tried was to hook +&- to external power source (of course 12v)
    and i hear it buzzes for a second. When i then hit the Check button, clock and odo displays lit up.
    But no "living" indications appear behind physical displays (rpm, spdo, temp, fuel) nor DIS.
    Has anyone any idea of what needs to be connected in order to get at least safe boot-up?
    Documentation is like sex, if it's good, it's REALLY good but if it's bad, still better than nothing.
    Project "Audi R4 - That hacked car"
    Dec 23 2011
    I'm just guessing, but doesn't the cluster need to detect info from the ecu to boot up?
    Apr 06 2015
    Sweden
    I too guess, it should boot up but into safe mode due failing immo verification.
    I'd hope to get it fully booted if/when immo is disabled. But that's maybe not possible without messing in firmware.
    Sent from my Nexus 5 using Audizine mobile app
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    You need power to the cluster, of course, and an interface to communicate to the cluster such as kkl? Check the pinouts.
    Blue connector:
    Pin:
    1 - terminal 15 positive (12 volts)
    23 - terminal 30, positive (12 volts)
    24 - terminal 31, earth (ground)
    25 - self diagnosis/K-wire (K-line)
    OBD connector:
    Pin:
    4+5 - Ground
    7 - K-line
    16 - 12 volts
    Aditional:
    Blue connector:
    Pin:
    22 - ground (coolant temp)
    Green connector:
    Pin:
    6-washer fluid (ground)
    7-brake pad sensor (ground)
    23 ,24 ,25 - ground for MFA
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Apr 06 2015
    Sweden
    Thank you! Will test out as soon as I'm home
    Jan 24 2013
    Chicago
    Quote Originally Posted by Dedsec View Post
    You may also want to check nefmoto out. There are plenty of knowledgeable folks out there to help you out.
    Apr 06 2015
    Sweden
    Quote Originally Posted by Denio24 View Post
    Already member there.
    Although my level of knowledge would just infect forums there if posting questions like where why and how
    Jan 24 2013
    Chicago
    - - - Updated - - -
    Just found this thread. Partly helping you out because I'm also always looking for more info regarding pinouts and all that. How to power on RB8 cluster: LINK
    Apr 06 2015
    Sweden
    - - - Updated - - -
    ahhhhh thank you, actually i did bump on to that pic in google search but ignored it for some unknown reason.
    Will probably dive deeper into it this night or tomorrow.
