Results 1 to 10 of 10
    Veteran Member Three Rings 1illA6's Avatar
    Aug 20 2012
    Arizona.
    OEM BW K04 Turbos with Inlets $1200 OBO
    SOLD SOLD SOLD SOLD
    OEM BW K04 turbos with Inlets.
    Pulled strong & ran fine prior to pulling them out. I did clean them up real quick due to a valve cover oil leak.
    3 on the studs came out removing the downpipe. I can leave the lines on or remove doesn't make a difference.
    Jul 04 2012
    Woodbridge, VA
    Mileage?
    Oct 10 2013
    Chicago
    How much shaft play do they have?
    Aug 20 2012
    Arizona.
    Quote Originally Posted by vavJETTAw36 View Post
    Mileage?
    Sorry should have added that, roughly 20k
    Quote Originally Posted by Crazyz007 View Post
    Side to side a little nothing crazy up & down none. Basically normal for dry journals.
    Once oil is running through them they're good to go. I had zero issues with them :)
    Sep 22 2016
    Florida
    900$
    Veteran Member Three Rings EMF614's Avatar
    Jun 15 2011
    cbus
    pm'd
    Ethan
    Single Turbo B5 S4
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Jl97 View Post
    900$
    I have a no-name set of K04's I'm selling for $400, save you some more money.
    Established Member Two Rings Rusty24's Avatar
    Mar 24 2011
    2012 Golf TDI
    Gilbert, AZ
    I would be all over these if my TDI buyback money was here already. GLWS.
    2001.5 S4|Neuspeed catback exhaust|Coded out EGTs|AWE vent boost gauge
    Sep 22 2016
    Florida
    750 if the studs holes arnt stripped
    Aug 20 2012
    Arizona.
    Quote Originally Posted by FlyboyS4 View Post
    Haha
    There's a nice set that looks like a rock went through them listed at $1000, if you want to try that.
    SOLD SOLD SOLD Thanks guys.
