Results 1 to 7 of 7
    Established Member Two Rings 123lilc's Avatar
    Mar 04 2015
    2002 Audi A4 GTX3071R, 2004 Audi S4 Avant 6M/T, 2008 Audi A4 Cabriolet,2018 L5P Duramax
    Champaign, Illinois
    Unhappy Oil in N75 and wastegate line
    OK so today I decided to put my manual boost controller in because it seemed my car was not building boost till way late so i thought either its the N75 or a boost leak, so i thought before i do a boost leak test i would try my manual boost controller (ball and spring) to see if it was the N75 causing the slow build in boost. So i got under the car and unscrewed the hose clamp off of the wastegate and as soon as i pulled the line off oil came out of the line, like alot, i would say the entire hose was filled with oil (not a very long hose). In order for oil to get all the way to the wastegate it would have to go through the N75 so the inside of the N75 was covered in oil as well. {QUESTION 1} what does this mean and why was the hose filled with oil??? So i drove the car with the MBC installed instead of the N75 (just left the N75 plugged in but just dangling with no hose connections) and my slow building boost problem was gone so... {QUESTION 2} is my N75 bad because of the oil that went through it and because its slow to build boost???
    Any help is greatly appreciated!
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    The whole intake tract is coated in some oil, combination of pcv and turbo seals leaking a bit. I wouldn't worry too much, but probably something worth cleaning once every few years.
    I think it might be worse when the pcv system is shit, as they tend to get. Might be worth revamping you haven't.
    Mar 04 2015
    Champaign, Illinois
    Quote Originally Posted by 5ktq View Post
    i have done the vacuum line delete so all that is gone, like the pancake n all that is gone
    Mar 04 2015
    Champaign, Illinois
    anyone else have more input?
    Mar 04 2015
    Champaign, Illinois
    seriously no one else knows?
    Aug 19 2013
    minnesota
    Quote Originally Posted by 123lilc View Post
    Drain it out. You might consider installing a provent 200. It sounds like you have an awful lot of recirculating oil from your PCV system. The question is why, bad rings?
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Mar 04 2015
    Champaign, Illinois
    so do you think my N75 is shot from the oil? Is that why the boost came on so slow?
