Results 1 to 4 of 4
    Aug 19 2013
    minnesota
    Dremel bit for cutting metal
    Does anyone have experience cutting metal with their Dremel? I have a Dremel 4200 with the new quick release Chuck. obviously the ceramic Dremel blades are great for cutting metal but they don't last because they grind away. I know that carbide and the diamond are the best kind of blades but I haven't been able to find any specific metal cutting blades for the Dremel. I want to cut open oil filters and other kind of awkward Cuts Like That. I want a bit that's reusable, any ideas would be cool. It's possible to get a bit that lets you screw down your own blade and fit that into the Dremel. So I know I don't have to get a Dremel specific blade. Ideally I'd have a carbide or Diamond blade that I can either attached to a bit and using the Dremel or a Dremel specific metal cutting bit.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Senior Member Three Rings Arnie91's Avatar
    Oct 28 2015
    London
    The dremel diamond disc lasts a lot longer. I went through all of my EZ speed cutting discs in about a week. I think ive only shaved off about 1mm from the Diamond disc. Costs a bit more but definitely worth it. https://www.amazon.co.uk/Dremel-2615...iamond+cutting
    Nov 24 2014
    DMV
    I always use the black "metal" ones for cutting. Not sure if those are the ones you're talking about. They do wear down, but they come in a pack of 5 for like $10 at sears, so you can always pop a fresh one in. For big jobs I use my angle grinder, and even the discs on those wear down.
    02 B6 A4 3.0 6MT Sport Package | Kenwood DDX9702S Double Din | Tint | B7 S4 Front Calipers & 345mm Brembo Rotors + Pads | Blauparts "U-Slot" Slotted Rear Rotors + Pads | ECS SS Brake Lines | APR Snub Mount | ECS Short Shifter | BFI Shift Knob | 034 Front Swaybar Endlinks | Lemforder RS4 Outer Tie Rods | SPC Adjustable Front Control Arms | Meyle HD Lower Control Arms
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    Typically burrs for shaping things, mini abrasive discs for straight cuts. For hardened steel swap the burrs for stones.
    I've only seen joke quality cut-offs with 1/8" arbor though, like this http://www.ebay.com/itm/100pc-Fiberg...-/252383314269
    Better ones are typically 1/4" for pneumatic grinders.
    For the price you'd be better off getting something like this for straight cuts, since the cutoff tools have a guard for when the discs invariably shatter http://www.harborfreight.com/3-in-he...ool-68523.html (better pneumatic if you have air).
    Though to be honest I have all that, and I'd probably just use a hacksaw on an oil filter. Or maybe punch a hole then use tin snips like a can opener.
    The burrs dull with use, and the abrasive dics and stones wear away, so there isn't really a single "good for life" bit.
