Thread: Grenade pin
    Jun 05 2014
    Olympia, WA
    Grenade pin
    I was a bit confused on the grenade pin. I think from all the videos I've been watching is the pin that holds the damper down in the hydraulic tensioner. I have 20 K on my timing belt, but I am replacing the water pump, thermostat and the belt. How do I use or re-use the hydraulic tensioner. Do i purchase a new hydraulic tensioner with grenade pin & fork out another 150 bones for a new one Or do I re-use the old tensioner that has 20-25K miles on it?
    Jun 10 2013
    United States
    You can use an Allen key instead of the pin. Find the biggest one that will fit in the hole. Then use the idler tensioner pulley to compress the tensioner. I think you use a 6mm hex. Compress very slowly. Once compressed insert the Allen key.
    Jun 05 2014
    Olympia, WA
    Thanks for the reply. That's exactly what I did to test for possibly re-use of this part. My question is how reliable are these dampeners? Should I use the old one that has 40K miles on it or purchase a new one? IF this part is prone to failure @ certain mileage, then I will get a new one. If not..... Hmmmmm, I may use the old. Just not familiar with Audi's yet.
    Jun 10 2013
    United States
    The old Subaru EJ22 used a very similar part and people almost always reused them and they lasted 300k. If it is an OE part I can't see it not lasting until your next timing belt job which should be in 50k miles or so.
    Compressing them slowly is key. Spend a good couple of minutes and apply very little pressure.
    Jun 05 2014
    Olympia, WA
    The dampener is a NTN brand. I put it in a vice and compressed it with a small socket. I think I will opt for a new one. I put an allen wrench in the hole, then back in the vise and let the tension off by relieving the tension while opening the vise. I did not open the vise super fast, but from reading ...Think a new one is in order :(
