Results 1 to 9 of 9
    Senior Member Three Rings Borg54's Avatar
    Nov 07 2005
    Sprinter Van, Too many motorcycles
    Marin, CA
    A7 Resonator Delete and X-Pipe installed...blah
    I picked up my car from the exhausts shop today. I had the resonator removed and an X-Pipe installed. To be honest I am kind of unimpressed with the results. I know it was inexpensive so I am not going to lose any sleep over it but it made only a very small difference. The car does sound better but if I had to do it over again I would just save my money and get a full exhaust.
    Anyone on here do the x-pipe first then get an exhaust? Any feedback on the difference?
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Different cars, but I had straight pipes and AWE tips installed on my S6. Volume definitely increased, but not nearly enough to justify the $1k it cost me. Got a smoking deal here on a used Milltek non-res and that was a much more noticeable change. IMO, the center resonator delete should only be done if you are looking for a marginal increase in exhaust sound.
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Quote Originally Posted by Borg54 View Post
    Hi thanks for posting
    Would u able to post video ? actually I would like to do the same. I am looking for little bit louder exhaust. But first i would like to listen.
    If u don't mind answering, how much did it cost u ? Thanks
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    It will be louder if you make it quad opening.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Jan 09 2013
    UK
    Yeah, resonators alone won't cut it, had to have them removed and then the centre muffler as well, the latter replaced with an x-pipe. Do you have normal or sports exhaust and have you had the centre muffled removed? Curious as the centre muffler has an x-chamber in it so how you have described it means you now have 2 cross over points which could cancel each other out i.e. less noise?
    Nov 07 2005
    Marin, CA
    Quote Originally Posted by P_G View Post
    I talked to the exhaust shop and you're correct. I should not have said "installed" an x-pipe as there is one existing. We did remove the resonator
    Jan 09 2013
    UK
    So the two small can shaped resonators are gone, now remove the suitcase sized centre muffler and I think you'll be happier
    Nov 07 2005
    Marin, CA
    I think I removed the center muffler and not the two can shaped things. So I should remove those too? Maybe that's why there wasn't much difference
    Jan 09 2013
    UK
    If they only removed the one which is the size of a suit case then it will be quiet. I did the same initially and replaced it with an xpipe and the noise was very subdued. Then the removal of the resonators (two coke can shapes ones, one on each pipe in front of the central suitcase muffler) really made a difference.
