Results 1 to 7 of 7
    Oct 28 2012
    near chicago
    Introduce myself with some quick, easy questions.
    Just picked up a 2013 s6. Absolutely love it. Sold the b5 s4 and the 04 a6 2.7t just last month. Still have an 03 rs6 completely built with ~550 whp.
    The 4.0t is in a completely different class. So smooth and seemless. I've done my homework and plenty of research but can't find a couple easy answers. Many of the posts I find to answer my questions are outdated and probably just common knowledge to you all by now.
    Do all s6's have an air suspension or was it an option? If an option what's the easiest
    Way to see what I have? I saw that h&r makes some sort of lowering module? That would be nice.
    I smell a coolant odor. Haven't pulled the plastic off the engine yet to look around but maybe a common issue to look for first? I read something about a turbo line leak that may be common?
    Will my older vcds read this car? I used it for all my c5 and b5 cars but compared to those there is a huge amount of tech in this c7. No problem buying a newer version if necessary. Vcds is a MUST imo
    Tuning- I know this engine has huge potential but I don't want to create other issues. With all the tech I'm wondering how a tune would affect it in terms of different modes etc. with both the 2.7t and 4.2t both had plenty of untapped potential but as some of you may know, tuned them quickly exposed weak links like transmission, heats issues etc.
    I will probably opt for a full set of winter wheels and tires but for now, because winter will fast approach, i may not have time and need to buy a set of 20" winter tires.
    I have a bunch more questions I'll continue to search for answers but that's my main concerns right now.
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    All s6 in America came on air, I will sell you my module if you want one I never use it
    Coolant lines on the turbos go all the time that is probably it
    Get the new version of vag, most do not work with the uds our cars use
    Slap some bigger turbos and tune away I had 50k on my s6 with no issues it had 40 on rs7 turbos
    Sent from my SM-G935V using Tapatalk
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Oct 28 2012
    near chicago
    Just tried my current vag com tonight. It's version 11.11xx. It read and connected but gave me an error about something not loaded on a few modules. Yep, I'll order a newer version tonight. Does the car need to be running to have the vcds com with the car? I did, but it's different since there is no accessory position like with a "manually keyed" car.
    Can you send me any info on that lowering module? I messed with vag com tonight and felt the car lower when I played with adaption. Hopefully I didn't screw anything up. Wife will be pissed :)
    I've taken the engine out of every Audi I've owned. Also completely disassembled two parts cars. I don't see any sort of "Bentley" manual for this car. Really like to have a workshop manual.
    I'll also look for rs7 turbos tonight :) sounds exciting. I'll do all normal maintenance ASAP; oil, plugs, filters. Are the timing belts an issue as in pretty much every previous Audi engine?
    Thanks for the info.
    Veteran Member Four Rings SilveR316's Avatar
    Jun 01 2013
    Downtown Toronto
    You might just need a software update for VCDS (vagcom). I'm using a cable I bought in 2005 when I was driving VWs and it works just fine with the latest software.
    You can lower the car a few different ways if you have air suspension. First is with VCDS but it is limited to how far you can go. You can also use lowering links (~$100 hardware solution). Or you can run a module such as the H&R lowering module or the Cete Automotive Active Suspension Wifi module. I'd recommend the Cete Automotive module as it's much cheaper, has wifi connectivity so you can configure it from your phone, and allows you to run different heights depending on which drive select mode you are in. The guy that runs the Cete Automotive shop is top notch and super responsive as well. I run this module, and I absolutely love it.
    H&R - https://tagmotorsports.com/h-r-lowering-module
    Cete Automotive Active Suspension - http://www.active-sound.eu/en/audi/a...air-suspension
    You can get a factory manual here: https://www.factory-manuals.com/audi-a6/s6&27&124
    I haven't bought one, but I've heard good things about them.
    2017 S6|Sepang Blue|Black Optics|Silver Mirrors|ASC WiFi Module|AWE Exhaust|034 Drivetrain Mounts
    2014 S4|Prestige|Estoril Blue|6MT - AWE 102mm|Alu Kreuz|KW H.A.S.|SPC Control Arms|20x9.5 Vorsteiner V-FF 102|Vorsteiner Front Spoiler|Deval Valence - Build - SOLD
    Oct 28 2012
    near chicago
    Thanks you! Plenty more reading to do now. Just read a write up doing the lowering with vcds but the cete module sounds like it may be better/easier. I'm headed there now. Thanks again for the response.
    Oct 28 2012
    near chicago
    Ok. One last thing. Looking for winter tires. Stock is 255 35 20. If I go to 245-40-20 it's 2.7% larger diameter. Will have issues with this size?
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Quote Originally Posted by slowguy View Post
    you shouldnt have any issues with that difference, as long as they are all the same size/ tread depth you'll be ok
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
