Hey guys looks for a bit of help with a p0299 code that will not go away.
To start, Ive boost leak tested up to about 20 psi and through that testing found and replaced many leaks/parts. The car now holds pressure very well so i feel thats ruled out.
A new OEM N75 was installed after much reading and most people seemed to point this way.
I have ran a few logs with vag com although I'm quite new to logging. The car is requesting upwards of 25psi but only receiving around 15psi. I have converted specified (~2500mb) and actual (~1900mb) by subtracting my engine off actual (820mb @ 5500' elevation or so) and multiplying by 0.0145?. These numbers seem very high to me on what i truly believe to be bone stock A4.
This morning I have disconnected the wastegate line to the N75 and had a drive. I was nervous about giving it too much throttle so Im not sure I accomplished much but it did seem to build boost easier and slightly higher numbers in my logs.
The n75 meters correctly ~32ohms if memory serves and logs show duty cycle in the 80% range at WOT when connected properly.
Very lost as what to try next.
help?!
