Results 1 to 1 of 1
    Senior Member Three Rings Indskyz's Avatar
    May 31 2016
    Virginia Beach
    Compression Test Mode - deactivation of spark and fuel
    HI,
    I need to do be able to cut off the ignition coils and fuel injectors from firing in order to do something similar to a compression test.
    My question is this...Does VAGCOM have the ability to put the ECM into compression test mode, or can I achieve the same results by disconnecting the CKP sensor and then attempting to start the engine?
    The spark plugs will be removed from the engine when doing this.
    Thanks for your input.
    Jae
    2010 A6 Prestige 3.0T
    GIAC Stage 2+ 93 & 100 Octane files
    AWE 57.55mm / JHM 179mm Dual Pulley (3.110 Ratio)
    PLM 26"x7"x2" additional HX
    Roc Euro Intake
    2.5" Custom Cat-back Exhaust w/Magnoflow Resonated X-Pipe and Mufflers
    Gutted CATs
    ST Coil Overs, H&R Rear Sway Bar
    19"x8.5 Avant Garde M590s Antique Bronze
    Spyder Tail Lights
