Results 1 to 23 of 23
    Established Member Two Rings chris120391's Avatar
    Aug 30 2010
    Las Vegas
    Non stretch head bolts
    So apparently eurospec no longer carries non stretch head bolts for our cars. Anyone know where I can get non stretch head bolts?
    01 A4 tqm Gt2871r - SOLD
    01 S4 k24'd E85 stock block - Current
    Aug 24 2014
    Newport Beach, CA
    I ordered my ARP head bolts from JHM, was $385. Not sure how much Eurospec charged for the ones they carried.
    2024 M3 Comp xDrive
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Aside from the ability to reuse them, why not just run oem?
    I've never read of an issue with stock head bolts.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Quote Originally Posted by christianb5s4 View Post
    Bout 1/4 of that.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Aug 30 2010
    Las Vegas
    Quote Originally Posted by DieselElectric View Post
    If I can't find them, I'll run OEM. Looking to build a high HP capable motor and figured eurospec head bolts would be ideal but believe head studs are still over kill.
    On that note, Victor Reinz, Elring, febi or actual "Genuine VW Audi" brand head bolts?
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Go away Christian nobody likes you.
    I just thought this over again in the context of what we talked about earlier and what your goals are with the build. I would drop the extra coin on the studs. With the level you're taking it to, you're probably going to be pulling the heads off, or the engine apart, a lot more than you realize. More power - more breaky break. The stretch bolts will hold, but they are one time use, and that will add up over time. No one plans on shit going sideways, or flipping onto it's roof on the freeway, but it happens.
    2005 A4 Avant 1.8t QTM
    Nov 02 2014
    Winchester, VA
    We talking likely block cracking territory?
    If yes, then yea I would probably go head studs just to minimize cost in the future.
    That said, keep a record of lengths so you know when to toss em.
    Aug 30 2010
    Las Vegas
    Looks like head studs it is lol
    Aug 06 2008
    Canadia
    You could go to a bolt supplier or look online, find the thread pitch and length and buy something with a higher tensile strength, i did that with my BMW 318i, stock bolts are 8.8 and i put in 12.9, torqued it all down to 75ftlbs in 25ftlbs increments (e30 m3 spec) and it worked like a charm.
    Some info on metric bolt tensile strength:
    http://www.engineeringtoolbox.com/st...es-d_1428.html
    the B5 S4 is like the mafia... there is only one way out!
    Nov 16 2010
    WetSide, WA
    Did you call them? I see them listed still.
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Quote Originally Posted by themadscientist View Post
    Go away Christian nobody likes you. No one plans on shit going sideways, or flipping onto it's roof on the freeway, but it happens.
    lololol
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Mar 02 2010
    Las Vegas
    Quote Originally Posted by chris120391 View Post
    I told you christian haha Head stud that shit! You'll blow a gasket before you lift a head.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by MacDaddy View Post
    No offence, but that's just ghetto. The E30 guys did that with "Metric Blues" but that's just because they were too cheap to fork over $300 for a proper set of head studs.
    ARP offers a solution for these motors, if the OP is doing a high performance build ARP fasteners are the way to go.
    Sep 11 2009
    NE
    I don't understand why ARP is so expensive. I used set of Eurospec stuff a while ago and it works fine. As a matter of fact, the head bolts paid for themselves couple times over years as I definitely had heads off couple of times since then.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Keep in mind even non-stretch bolts have a usable life. They can only be torqued and retorqued so many times. However, if you are running into that problem you have built a shitty motor if it needs to come apart so many times
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Jan 29 2009
    Quote Originally Posted by julex View Post
    We all know price is dictated by market...
    I don't know what bolts from Eurospec you guys are talking about (just tried to google images) and from what I see they're just normal bolts (probably locally sourced higher grade hardware) and not actual studs which is a big, big difference in how the fasteners work.
    That would be a real difference if so.
    Aug 24 2014
    Newport Beach, CA
    You guys are lucky my quote and multi-quote isn't working right now, savages.
    2024 M3 Comp xDrive
    Nov 02 2014
    Winchester, VA
    Quote Originally Posted by redline380 View Post
    Thus the comment about taking measurements with a mic before initial use, and after every re-use.
    ARP includes paperwork and acceptable stretch limits to monitor wear throughout their life. At least they did on the last set I purchased.
    Aug 06 2008
    Canadia
    Quote Originally Posted by NOTORIOUS VR View Post
    He asked and i gave him an answer.
    Its not like audi makes their own bolts, and im not talking about bolts made in china either. ARP stuff is nice (ive used it before) but lets be honest, its overkill and most people install it half assed or dont use it to its full potential.
    Jan 29 2009
    Right, I know why you did it... I was just giving a little more context... Wasn't a jab at you for going that route.
    Aug 06 2008
    Canadia
    I wasnt even mad! Lol
    Aug 23 2016
    richmond VA
    OEM they around 100$ for set .
    Mar 02 2010
    Las Vegas
    ARP is trusted in pretty much every car/truck scene. I went with nothing but ARP on my mustang build, from oil pan and water pump bolts to heads and rotating assembly. Its better to be safe than sorry. Also, if you call them they can match any bolt you may possibly need and you can buy them individually directly from them. Very knowledgeable guys over there.
