    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    Brake replacement process question
    For those who have replaced their front and rear brakes separately (the front brakes generally wear out before the rears), have you had any issues with brake noise or performance?
    I will be replacing my pads and rotors with OEM (I love the bite) again and my rears have 2mm more than the fronts. Last time, I replaced with OEM, used Brake Quiet gunk, and went through the bedding procedure resulting in little to no brake noise. I am concerned those results will change if I do not change the rear pads and rotors at the same time as the fronts. If I only change the fronts, should I go through a bedding procedure? Your feedback would be appreciated.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    I got my car used with fronts replaced only without issue. So I recently upgraded my rears and everything is still fine. I don't see why you wouldn't bed the brakes even if its just new fronts. It won't hurt the rears.
    2013 S4 Monsoon Grey | APR Stage 2 Single Pulley | Roc Euro Intake | 034 RSB + Drivetrain Inserts + Control Arms | CR-15 | KW V1
    RIP 2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Control Arms | Pipercross Filter
    Active Member Two Rings atvhead's Avatar
    Sep 06 2016
    A4
    NH
    mine too had new fronts put on just before purchase. Rears look to be possibly original. no issues.
    2007 A4 2.0T AWD....100% stock!
    Jun 27 2011
    Why would the front pads affect the rear pads?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 05 2010
    Central IL
    Thanks much to all. You will have to excuse me -- I am ignorant when it comes to this type of thing and would rather ask than make a mistake I regret.
