Hi Guys,
I'm kind of at a loss at this point and was hoping I can get some good ideas what to check next. I screwed up something on the weekend when I replaced my thermostat and waterpump (it was overheating) but I cannot figure out what. The job itself went well, I labeled the vacuum lines accordingly and made sure that everything went back into the appropriate connectors.
Now when I start my car it revs up and down from 1100 to 1600. It almost sounds like it wants to die but it never does. I drove it around the block to see if I can get some codes - the only thing I got so far was P050A but no CEL.
I checked and re-checked all the vacuum lines, removed the Supercharger twice to make sure I didn't miss anything underneath but I cannot find the cause. I also replaced the coolant temp sensor on my first run but put the original back in after this issue started to see if that was the cause (unfortunately it wasn't). I sprayed brake cleaner around the vacuum lines and where they plug into but nothing changes the engine behavior so I don't think it's a vacuum leak.
I would be very helpful for any pointers.
