Results 1 to 17 of 17
    May 31 2014
    Alabama
    ECS Engine Mounts?
    Hello all, forgive me this has been posted numerous times. I just wanted clarification on the ECS engine mounts.
    Looking at their website, there are multiple options for Left vs. Right engine mounts. If I wanted to get a set, which one would I need? Also, is there a huge advantage getting the engine mounts? I am getting the front/rear differential mounts & transmission mounts installed next week -- just wondering if it's worth the extra money to get the engine mounts as well.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Quote Originally Posted by AudiS4SD View Post
    I did engine mounts and noticed a big difference, until you get used to it and forget what it used to feel like lol. Went with 034. But you would need the left and the right . 034 had them as a package, so i'm not sure what ECS does.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Aug 12 2013
    Lexington KY
    So, have your engine mounts gone bad man? You can surely tell if they're bad or not. You can pull your underpanel and check them. If you see some leaks, you know they've gone bad. Or if your engine is vibrating much more than it used to.
    May 31 2014
    Alabama
    Quote Originally Posted by ojmcneill View Post
    No, they're not bad. Just wondering as the shop I'm using said "Oh, no engine mounts?"
    So, it got me thinking -- maybe Audizine has been pleased with just swapping them with 034/ECS. But, doesn't look like it's a major player right now.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I'd go with 034, but I'd also wait until the stock ones go bad to replace them...
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    May 31 2014
    Alabama
    Sounds good thanks. Just wanted to make sure I didn't need something else.
    Looking forward to the transmission and rear diff mounts!
    May 31 2014
    Alabama
    ECS Engine Mounts?
    Ok -- I called the shop to book an appointment and get a labor estimate. It comes out to $800+? (Transmission and rear diff mounts)
    Is that correct or did the shop misunderstand what was getting installed? The parts cost $170 from ECS and both are rated as "easy" installs.
    Maybe I'll just install the transmission mount for now...
    Jun 28 2016
    US
    $800? Dude, seriously, download the install PDFs and take a look over them. The trans mount is just two bolts you undo and then put them back in. If you can turn a screw driver, you can do work like this. The rear diff mounts are a little bit more time than that, but still not difficult. If you have any mechanical capability, it's easy to do. I did the trans mount without even needing to jack up the car, but I'm pretty thin and can scoot in under the car a little bit and reach each of the bolts. I'm serious dude, the shop is robbing you blind.
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Quote Originally Posted by SwankP3RF3ct10n View Post
    ^ This. This guy just saved you a lot of money. Maybe send him a fruit basket.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    Your shop must have been mistaken, it's an hour or hour and a half DIY job at most.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by LordMagnet View Post
    fruit basket..😂. I can't believe how greedy some shops are.
    Sent from my Nexus 7 using Audizine mobile app
    May 31 2014
    Alabama
    ECS Engine Mounts?
    They also claimed having to get a realignment because they have to drop the subframe. The PDF for the rear diff doesn't state anything about dropping the frame. I hope the shop just misunderstood. I'll just show them the parts in-person.
    Are you guys saying for both tranny and rear diff mounts it takes 1.5 hours?
    I'd love to do it myself, but I'm not going under the car unless I can safely jack it up or find a bay to walk under it.
    Jun 28 2016
    US
    Dude, for the rear diff mounts I just jacked up each side and put it on jack stands in the back. Then I used the factory jack with a small piece of 2x4 and turned it by hand (without the crank bar) slowly to jack up the diff up as it needed to according to the directions to install them. Now, if you're talking about the subframe inserts from 034 for the back, then those are a bit more involved, but that subframe drop shit this shop is telling you is bullshit. I'm gonna tell you why they're telling you all this shit and giving you a high price. Because you're bringing them such simple parts to install, they know you don't know shit and can pretty much treat you like an idiot, so they're jacking up the price to make a quick buck. I'm telling you dude... you're getting taken for a ride, but that's your call man. Good luck.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Just download the install docs and provide them to the shop - then ask them to review and update their quote prior to starting any work..... If they still stand by $800 - it's time for a new shop.
    My guess is they didn't understand the parts - and were going by the OEM replacement procedure.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    May 31 2014
    Alabama
    Quote Originally Posted by grovlet View Post
    Will do for sure. I will not accept getting pushed around by the shop; I know I'm not completely versed in all this but I know when I'm getting thrown around.
    Will update you guys once I get more info.
    May 31 2014
    Alabama
    Ha, the shop called back and said they misunderstood. $200 for everything. That's sound better. We'll see if I do that or have a DIY project...
    Dec 03 2008
    2018 SQ5
    Dude, the drive train mounts are literally the easiest thing to install on this car. It took me about half hour to do each one, including jacking up the car for each one as I installed each part one at a time to test improvement.
