The other day I was running some errands. Car started fine & ran with no issues. Half pulled into a space & ran into the bank. Come out, jump in, turn the key & NOTHING. No crank Tried jumping it, not the battery. Finally got it towed home & up on stands. Opening the box with the ECU & checking the relays & fuses. All was good. Finally figuring out it had to be the starter by the looks of it
Just a few pointers for anyone tackling this job. The easiest way to get to that 5/8 bolt on the top is actually through the wheel well. Above the axel is enough space to fit your arm. Using a short socket & patience....the bolt is long. Believe me I figured this out after enough time. Other than accessing that bolt it was an easy job.
Anyone in the NY/NJ area ever need your Starter rebuilt these guys are awesome
S M Ignition Inc
24-02 82nd St
Jackson Heights, NY
718-458-5858
Dropped it off & it was ready in 1hr
For around $100! Great work
Took about ten minutes to put it in & start it up.
