Hey Guys!
The car was driven through hurricane Matthew and while driving across some moving water on the road the car began to slip or misfire. The water was probably 1/2 foot deep, I pulled over drained the intercooler pipes which had oil on the passenger side and milky oil on the drivers side. About a half of a water bottle on each side. I checked the air filter and it was dry. Car idles fine. From a dead stop you can accelerate as fast as you want to go and it drives normal. If you accelerate to around 40 MPH, it will start to slip or miss and when trying to hold speed the RPMs drop 500 revolutions and go back up. There are no lights on and nothing in the memory for fault codes. After letting it sit and run for 45mins to an hour, it missed/slipped less. Replaced the spark plugs and 2 coil packs(that was all that was available last Sunday) and it didn't change anything. I dropped it off at a shop and they advised to replace the turbo. Turbo replaced, same issue. Turbo was bad but wasn't the problem. The did a leak down/ misfire detector and nothing came up. Has anyone had a similar issue or have any ideas? The shop isn't sure where to look next and neither am I. Kicker now is the car is 800 miles away from home.
