Results 1 to 3 of 3
    Oct 20 2012
    Danbury
    Help with Fault Codes
    My 2009 A4 was recently scanned using vagcom and a few codes came up but couldn't understand what some of them meant. I was hoping to get an idea of what some of the codes meant in terms of getting rid of them. I am most curious about the one in RED as my DRL's and headlights don't work.
    Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
    Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
    Component: 2.0l R4/4V TF H14 0001
    Revision: E1H14---
    Coding: 0104010A190F0160
    Shop #: WSC 42744 001 1048576
    ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
    ROD: EV_ECM20TFS0118K2907115AL.rod
    VCID: 79F86AD7F8B8D78AFB-802C
    3 Faults Found:
    4698 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    Intermittent - Not Confirmed - Tested Since Memory Clear
    4699 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    5664 - Mass Air Flow Sensor (G70)
    P0100 00 [096] - Supply Voltage
    __________________________________________________ __________
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 F HW: 8K0 907 064 F
    Component: BCM2 1.1 H80 0143
    Revision: 00002001
    Coding: 090100
    Shop #: WSC 02399 823 56573
    VCID: 336498FF9254EDDA71-8066
    Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
    Component: FBSAUDIB8 IDG H37 0060
    Serial number: 0508000053997002
    Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: ELVAUDIB8 H36 0041
    Serial number: 0208000066046011
    1 Fault Found:
    02638 - Enabling Steering Column Lock
    009 - Open or Short to Ground
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
    Component: BCM1 1.0 H22 0253
    Revision: 05022001 Serial number: 00000000125285
    Coding: 26001031063C00010000000300001D0D0F1452080000000100 0000
    Shop #: WSC 44575 001 104857
    VCID: 306E97F36342D6C20C-8064
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 240908 H06 0070
    Serial number: SWF08090246204
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 941 531 F HW: 8K0 941 531 F
    Component: E1 - LDS H07 0070
    Serial number: 00000000002209080599
    5 Faults Found:
    03354 - Bulb for DRL and Marker Light; Right
    012 - Electrical Fault in Circuit
    01495 - Bulb for High-Beams; Left (M30)
    03188 - Bulb for Side Marker Light; Front Left
    00927 - Terminal 30 (Right)
    011 - Open Circuit
    02745 - Bulb for Daytime Running Light; Left
    Sep 09 2010
    Destin, FL
    Here's the thread to post this in...
    http://www.audizine.com/forum/showth...ting-and-Fixes
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    looks like an electical issue. are your lights working? seems like bulb issues with the HIDs
