Results 1 to 6 of 6
    Oct 17 2016
    Panorama city CA
    05 audi A4 1.8T leaking fluid under driver side
    Hello I need to help because honestly I don't what is going on with my car I was Gonna park and as soon as I put it into Drive I heard a pop when I finished parking I noticed there was there was a trail Of fluid coming from my a4 I tried seeing what it was but there is a plate under and atm I can't remove it because I haven't been able to get a jack when I press check the only thing it shows is something with the coolant and also oil pressure can Someone help me to find out what is wrong or what broke
    Sent from my SM-G900T using Audizine mobile app
    Established Member Two Rings bwizard's Avatar
    Oct 10 2016
    Colorado Springs, Colorado
    Need to get eyes on it need pictures
    Sent from my S4's talk to text @ a buck thirty
    weekly driver 02 S4 2.7t auto stock
    Wife's 04 A4 1.8t auto stock
    Daughter's 97 A4 AEB Bored to 2.0t K04 sport cams
    My role family tech.
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    what color was the fluid?
    Oct 10 2016
    Maybe your oil cooler cracked ,head gasket,cracked block,expansion tank blew up then knocked off the oil filter.
    Apr 17 2016
    kc
    Too vague to diagnose. Take it to the garage!
    Veteran Member Three Rings strtdrms's Avatar
    Apr 03 2012
    Noblesville, IN
    Pop the hood and check your fluid levels. Then go from there. After a spirited run, I was letting my car idle and heard a pop and fluid start pooling under the car. I popped the hood and check my fluids. Power steering was almost empty. Checked my lines and noticed the line to my power steering cooler popped off.
    2003 A4 1.8T Avant 5MTQ My Progress Thread
    2003 A4 1.8T Avant TIP - Daily Driver
    Instagram: mr_avant
