Results 1 to 3 of 3
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Misc. B5 A4 OEM+ parts
    See my Denver Craigslist ad. I will ship most things insured and with PayPal.
    http://denver.craigslist.org/pts/5886629795.html
    • 1x B5 RS4 75mm Throttle Body (07D 133 062). This works with the RS4 intake mani or the S4 intake mani with a throttle body adapter plate. Some Throttle Body Boots will be able to fit on with massaging. $150
    • Audi TT front caliper carriers for 312mm vented rotors on B5 A4 Passat This is the cheapest, easiest bolt on OEM+ front brake upgrade for your B5. Uses stock knuckle location to mount your stock calipers and upgrades your front brakes to allow bigger rotor and venting. $120
    • 1x B5 S4 Headliner Set in Onyx/Black NOT a complete set. The set is missing a sunroof slider. This is a sweet full black interior upgrade for B5 A4s $200
    • 1x B5 S4 Headliner in Onyx. Has sag in rear for $40. Sag can easily be fixed w/steamer and paint roller or some new adhesive before install.
    • 1x B5 S4 A pillars in Onyx. Some minor defects. No broken tabs. Have airbag plugs. $40
    • 1x B5 A4 S4 MK4 1.8T 2.7T Forge 007 Diverter Valve Polished billet aluminum DV in excellent condition. All o-rings are in good shape, it has been cleaned and re-lubed/serviced. Superior aftermarket, quick response DV that is re-buildable and serviceable. No longer made, like new $140
    • 1x B5 S4/RS4 AllRoad A6 2.7t RS4 85mm Intake Accordion Hose (078 129 627 P) $50
    • 2x B5 S4/RS4 AllRoad A6 2.7t Beru ICMs $20ea
    • 1x B5 S4/RS4 2.7T K&N style drop-in airfilter for airbox Could fit other airboxes $10
    • 1x B5 A4/S4 Independent Fog Light Relay. Modified to run your fog lights without turning on your headlights (see picture). This is an easy plug and play 5min install. (8D0 907 01 B) $30
    • 1x B5 A4/S4 Battery Tray Cowling(8D1 819 447 A) with rubber $40 and Battery Cover (8D1 819 422) $15 $50 total
    • 1x B5 A4/S4 Aero Wiper Arm Conversion Set. Improved wiping at higher speeds where wiper will not hop/skip, sleek low profile where arms are unnoticeable at rest from driver seat(See Picture), sits below wiper blade instead of on top. Effectively scooping and wiping debris instead of running over it. OEM plus look. Used $40/pair
    • 1x A3/A4/A5/A6/S4/RS4/Q5/Q7 Multifunction Steering Wheel (MFSW) Controls (mode/BT/Vol/scan) (4F0 951 527 C) $40
    • 1x OEM Audi mobile phone Pure nostalgia. Plug it in to complete your accessory package. Marvel at its epic greatness. Convert it to a bluetooth headpiece. $20
    • 2x B6 A4/S4 Rear Rubber Floor Mats in black (8E0 061 511 041) $30
    • 1x B5 A4/S4 set of PreFacelift Taillights inblack. Excellent condition easy to modify(swap wires 2and4 in connector) to light up on your Facelift A4/S4. Stand out and look different! $50/pair
    • 1x B5 A4/S4 Front Seat Track End Covers, unbroken w/ no screw covers in Terra Cotta $10
    • 1x B5 A4/S4 Passat Roof Mounted Sunglasses Holder in Grey. Fits in roof handle location. They hold large sunglasses easily. OEM $10
    • 1x C5 Allroad Bumper Mesh Grille OEM. All three pieces including fog light holders. $50/set
    • 1x MK4 Jetta/Golf/GLI/GTI/R32/Beetle Donut Headrests in black cloth for front bucket seats. $30
    • 1x B6 A4 Cabin Filter Cowling OEM (8E1 819 447 A) $15
    • 1x B5 A4/S4 OEM Wiper Arm Set, hook style. $10
    • 3x B5 A4/S4 Complete OEM First Aid Kit(8D0 860 281 C) $10
    • 1x B6 A4/S4 A6 A8 Black Trunk Net (8E5 861 869) w/ pouch area $40
    • 1x A4/S4 A6 A8 Beige Trunk Net (4A9 861 869) $15
    • 1x A4/S4 A6 A8 Black Trunk Net (4A9 861 869) $25
    • 1x '97 B5 A4/Passat Computer/ECM/ECU for 1.8T with AEB engine code, drive by cable(8D0 907 557 N) Already have a tune and want a new one? Use this ECU and sell your old one instead of writing over it to regain money! $40
    • 1x '01-02 B5 A4/Passat Computer/ECM/ECU for 1.8T drive by wire(4B0 906 018 CH) Already have a tune and want a new one? Use this ECU and sell your old one instead of writing over it to regain money! $40
    • 1x C5 A6 Oversized PS Reservoir Cover $5
    • 1x B5 A4/S4/Passat C5 A6/S6/Allroad Boxster Sachs Throw-Out Bearing(04 3151 2719 37) $25
    • 1x B5 A4 Grey Headliner Pieces(lights, handles) $20
    • 1x B5 A4 Grey Headliner great condition, no sagging $25
    • 4x B5 B6 A4 Cigarette Lighter $5ea
    • 4x 710/A/B Diverter/Bypass Valve (fits audi, porsche, saab and VW 1996-2002 turbo cars) $5
    • 1x B5 A4/S4 Rear Differential Carrier (8A0 599 133 B). Bushing still in good shape. $20
    • 1x B5 A4/S4/Passat Slotted Coolant Cap from A3, different than most, blue $10
    • 1x B5 A4/Passat N112 Valve $20
    • 1x B5 A4/Passat N249 Valve $20
    I am WILLING TO TRADE my parts and cash for: Rear Black A4 Bumper, Black B5 facelift driver fender, 5x112 WCI or Rotiform wheels, LC-1, UEMO or Zeitronix wideband, B5 or B6 vent pod for gauges, Cupra R lip, B5 RS4 door handles(black), RS4 grille, B5 In.Pro mirror housings, Depo E-Codes w/ city lights, CX Racing intercooler piping, Treadstone FMIC, 034 B5 A4 1.8T FMIC, AEM water meth nozzle, 034 sub frame bushings, water-meth bungs, silicone engine hoses (black), B5 cold side intercooler piping, manual boost controller MBC, Silver B6 door blades, B6 S4 lower center grille, Apikol B5 bushings for rear diff carrier, B5 DTS Drive Train Stabilizer, B5 034 or Hotchkiss Rear sway bar and reinforcements, GT28RS, Maestro Tuning Suite, AEM Methanol Injection Nozzles, wheel spacers and a wheel stud conversion kit
    Keywords: Audi VW Volkswagen AE 18T turbo EVO AEM draft design APR GIAC 5x112 Motoza B5.5 B7 B8 B8.5 RS4 Snow Performance Devils Own methanol innovate 034 IE Integarated engineering Forge bypass garrett precision borg warner cold air intake chip chipped C2 PES magnaflow billy boat borla xs-power ftg project B5 ECS modded mods tubobits go fast HFS4
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    May 08 2014
    CLFX, Denver
    bump
    May 08 2014
    CLFX, Denver
    bump
