Results 1 to 10 of 10
    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    Question Anyone done a DIY MAF hose?
    Im going to get an 85mm MAF but i really would rather not buy the 75 dollar 034 one. I feel like there is gotta be a way to make your own with some silicon hosing from amazon/ebay. Like a 3.5 to 3.5 with a 45 degree elbow in it. also who runs a coupler from maf to airbox?
    Jan 06 2009
    Im sure you can get a 45 degree coupler and trim it a bit. Summit Racing is great for this sort of thing. Not sure if it will be much cheaper though. Maybe sub $50 + time to modify it assuming it works at all.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    Quote Originally Posted by 616_S4 View Post
    do yourself a favor and spend the money on an engineered maf housing nd intake pipe...the only modifying I did was mating my maf housing into my airbox, chiseled away at the ribs on the inside so my maf housing would slide all the way in till it butted up against the inside of the airbox, the hose after the maf housing just get the 034...its easier that way. the money you save vs the headache you may create later for trying to tune is not worth it...
    2008 Ibis RS4....GETing tuned
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Mar 07 2016
    2001 S4
    What about something like this? its only like 10 bucks
    Mar 07 2016
    2001 S4
    Quote Originally Posted by axnjaksn View Post
    how did you tighten the maf to the airbox tho?
    Aug 06 2008
    Canadia
    Amazon, ebay, etc, twke your pic, usually run about $20
    the B5 S4 is like the mafia... there is only one way out!
    Mar 07 2016
    2001 S4
    Ok guys randomly was thinking and the idea popped into my head, what about just some 3.5 inch exhaust tubing having it bent to the same angle as the accordion hose and then using silicone couplers on the connections. Would be a cheap solution and would not have to worry about the chance of collapsing under pressure. Just a thought. let me know what you think!
    Dec 10 2013
    Borden, Ontario, Canada
    Use aluminum then. Won't heat soak so much.
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Also keep in mind those things can suck flat, depends on how restrictive the intake is.
    Buddy said he watched his rs4 accordion suck down on the dyno. Stock airbox 605s at the time.
    I imagine you want to pay even more attention to the softer silicone ones.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
