Results 1 to 7 of 7
    Apr 07 2012
    Montreal Quebec
    RS4 Power loss @5500 RPM
    Hi guys i was hopping some of you could help me out with my RS4 issues...
    I've recently installed the full ebwerks exhaust with high flow cats and O2 spacers to avoid any CEL...
    I dont know if its a coincidence with the exhaust install but when i push the car i dont feel the kick i use to have at 5500rpm...
    actually to be correct its really bad starting from my 3rd gear where it almost feels like a fuel cut occurs...1st & 2nd seems tolerable but once on the highway it gets bad....
    BTW no CEL or codes stored in the ECU!
    So after searching the interwebs here are some points i checked:
    - removed and cleaned the airbox flap
    - carbon clean performed 8000kms ago
    - spark plugs and coils 11000 kms ago
    - checked for any vacuum leaks or pinched tubes
    - made sure to plug the exhaust tubes that were connected to the oem exhaust
    So i honestly dont know what area to attack...i do have fresh injectors but i wanted to stretch it a bit more to perform a carbon clean at the same time....
    Whats driving me nuts is that a have no codes to work with...
    Thanks again for your input:)
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    cap your rear vacuum lines for the exhaust flaps.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Apr 07 2012
    Montreal Quebec
    Quote Originally Posted by your daddy View Post
    Yeah i made sure they were capped properly....no vacuum loss there
    Check the vacum valve placed under the airfilterbox the one thats controls the flap In the airfilterbox.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    You can run a vacuum diagnostic test in VCDS. That may help eliminate some of the potential culprits.
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Apr 07 2012
    Montreal Quebec
    Thanks guys ill check those 2 options... however if i were to have a faulty coil-injector or spark plug can we agree that i would automatically get a CEL?
    May 29 2007
    and not pick 5500 each time. its most likely vacuum related.
