    Veteran Member Three Rings Toronto5.5's Avatar
    Apr 03 2011
    SPC Adjustable Rebuildable Control Arms - Used - $100 - Complete Upper Set
    Pictures to be added.
    Located in Mississauga, pickup only.
    http://shop.achtuning.com/SPC-Adjust...-B5-B6-B7.aspx
    SPC Adjustable Upper Control Arm Kits allow ±1.5° camber or caster change on the Audi B5, B6 and B7 chassis vehicles. These arms directly replace the factory fixed length front upper control arms, allowing for easy adjustments after installation. Engineered for the street and track, the forged 6061-T6 aluminum ends with 18mm threaded adjuster links assure this is the strongest kit available. Maintenance free balljoints and bushings provide factory ride, handling, and NVH (noise vibration and harshness) performance.
    SPC Adjustable Upper Control Arm Kit Vehicle Fitment:
    The SPC Adjustable Upper Control Arm Kit is designed to fit the following vehicles.
    Fits:
    1996 Audi A4
    1997 Audi A4
    1998 Audi A4
    1999 Audi A4
    2000 Audi A4
    2001 Audi A4
    2002 Audi A4
    2003 Audi A4
    2004 Audi A4
    2005 Audi A4
    2006 Audi A4
    2007 Audi A4
    2008 Audi A4
    1999 Audi S4
    2000 Audi S4
    2001 Audi S4
    2002 Audi S4
    2004 Audi S4
    2005 Audi S4
    2006 Audi S4
    2007 Audi S4
    2008 Audi S4
    2006 Audi RS4
    2007 Audi RS4
    2008 Audi RS4
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    How are you?
    What condition are these in? I have a set on my daily, but might need a set for a track car.
    Thanks.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Apr 03 2011
    PMs replied :)
    Active Member One Ring t-gunn's Avatar
    Jul 17 2017
    North Carolina
    No possibility of shipping?
    Sent from my VS995 using Audizine mobile app
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Still available?
    Sent from my SM-G955W using Audizine mobile app
    2007 RS4
    2000 B5 S4 stage 3
