2002 Audi S6 Avant BBD Engine with 034 Motorsports Motor Mounts
Engine is running strong and has zero issues
Can be sold with or without 034 Motorsports RS4 clutch & lightweight aluminum flywheel
The following work was completed within the last year before deciding on RS6 conversion:
Engine - Timing
Timing Belt
Timing Belt Relay Roller
Timing Belt Roller
Timing Belt Tensioner Roller / Tensioner Lever w/ Roller
Timing Belt Tensioner Dampener
Water Pump w/ Metal Impeller
Thermostat w/ O-RIng
Accessory/Serpentine Belt
Accessory/Serpentine Belt Tensioner
Accessory/Serpentine Belt Roller (2)
Socket Head Screw w/ Collar - Front Crankshaft Allen Bolts (8)
Fan Clutch
Intake Manifold Linkage Arms (Gruven)
Camshaft Tensioner Gasket (2)
Camshaft Sealing Cap (2)
Valve Cover Gasket Set (2)
Ignition Coil (oddly, just one needed to be replaced)
Spark Plugs (New in box & not installed yet)
Engine – Gaskets, Seals & Plugs
Valley Pan Gasket
Intake Manifold Gasket (2)
Rear Main Seal w/ Flange
Rear Main Seal Gasket
Engine – Mounts
Motor Mount – Street Density (2) (034 Motorsports)
Resistor Bypass, Active Motor Mount (034 Motorsports)
Motor Mount – Front
Oil Cooler / Heat Exchanger
Oil Cooler Tube (Gruven)
Oil Cooler Gasket Set
Heater Core Hose
Oil Filter
Clutch & Flywheel
Audi 2.7T RS4 Hybrid Clutch Kit (034 Motorsports)
Flywheel, Aluminum, Lightweight 2.7T (034 Motorsports)
Here are pictures of some of the engine work being done:
