Results 1 to 18 of 18
    Sep 29 2007
    02 S4 /07 S4 / 11 Q5 / 16 S3
    Clarkston, MI
    weird sputtering
    so this problem started a few weeks ago and so far i cant figure it out
    car starts / runs fine except when you get on the gas hard it starts sputtering, especially at wot then it sounds like a machine gun, like its misfiring or something
    checked plugs they looked fine, replaced them anyway but no change
    thought mybe it was bad gas but i have used several tanks and even tried water remover and octane booster but again no change
    i have a catless downpipe and awe exhaust, have had it on there for 6 months or more with no problems
    the only codes i have are these but are they normal because its catless
    P227000 - O2 Sensor Signal Stuck Lean; Bank 1 Sensor 2 intermittent
    P042000 - Catalyst System,Bank1 Efficiency Below Threshold static
    i also have a jb1 but its on map 1, but even on map 0 (disabled) the problem is there its just not as bad, the problem seems to be worse with more boost
    looking at the readouts of the o2 sensors they are both reading, sensor 1 is 1.8-1.9v at idle and sensor 2 was around .9v if i recall, both change while you give it gas
    any ideas? i was going to remove the jb1 totally but didnt do that yet
    16 S3 with awe exhaust, usp downpipe, JB4
    2000 911 C2
    Sold 02 S4 with Apr stage 1 / millitek catback
    Sold-07 S4 with DTM kit, JHM tune, stasis exhaust, 19" VMR 710,
    Aug 08 2016
    Best bet is to take the jb1 off and check all the connections to see if a wire came loose if you've been connecting and disconnecting it frequently.
    Senior Member Two Rings TurboNate's Avatar
    May 16 2015
    El Cajon/CA/San Diego
    Try replacing coil packs. That was my issue. If that doesn't fix it, try PCV valve
    2009 A4 Premium+ Quattro
    APR Stage 2 | CTS Turbo High Flow Cat | Custom Intake System | AG 19x9.5 m580 w/ 10MM Spacers In Rear | RS Mesh Grill | 5% / 20% tint
    AKA: NathanMansoor
    Aug 08 2016
    Quote Originally Posted by TurboNate View Post
    Those are two expensive guesses. Isn't their a way to check to see if they are actually faulty.
    May 16 2015
    Quote Originally Posted by AnthonyA3 View Post
    Not really to be honest I'm sure it's the coil packs tho cuz I had the same exact issue with my B8. I replaced both spark plugs and the coils and it fixed the issue
    AKA: NathanMansoor
    Sep 29 2007
    Clarkston, MI
    i had coils go bad on my B7 and it was throwing codes, did yours throw a code?
    if the jb1 removal doesnt fix it i think i will take it to audi to figure out
    2000 911 C2
    May 16 2015
    Quote Originally Posted by tekkie View Post
    I had no codes what so ever, not until I replaced and there were issues. Long story short, coils were the fix, and no codes initially
    AKA: NathanMansoor
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I am not sure if the O2 sensor stuck lean is a normal code for a catless DP. Usually, lean codes come from the 1st sensor. But, I guess it could come from the second sen sensor as well. The catalyst inefficiency is normal. Sounds like it really going lean and you aren't getting enough gas, i.e. the sputtering. It could also be bad/stuck injector but it would be unlikely with the amount miles ect., on the car.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Dec 21 2015
    Melhbach, Germany
    With ANY high boost car you REALLY REALLY should be running a REAL tune with a Downpipe... ESPECIALLY with a catless one. A JB1 ONLY changes the boost signals to add more boost which REALLY X2 multiplies the REASON why you should have a tune addressing the DP. Now sure you could get away with it for a while, but if it was my car and my motor... I wouldn't be gambling with it. MORE BOOST + NO CATS + Downpipe + STOCK ECU programming = flirting with disaster. Sure you want to keep the warranty.. but catless DP is usually the breaking point of caring about the warranty anymore. I'd at least put it on a dyno to ensure your within safe limits after you fix the issue.
    Your symptoms are of a non firing cylinder. AKA: plugs or fuel injector in one cylinder. Since its under boost only... id wager a faulty Fuel injector causing a misfire. Little secret on what causes pistons to go on vacation... misfires.
    A modded car as such would speed up any weak links.
    2016 Audi S3 (CTS Intake, JB1, dogbone, AWE track catback..)
    2002 Trans Am WS6 (Sold)
    2012 SRT8 (Sold)
    1997 Viper GTS (Sold)
    2006 Z06 (Sold)
    2004 Viper SRT10 (Sold)
    2010 GT500 (Sold)
    Aug 28 2013
    Quote Originally Posted by Blaine View Post
    What I meant about a bad injector being unlikely, in that I believe the injectors are fine. They are just having trouble keeping up with the fuel requirements on the stock tune. Also, the rear O2 stuck on lean condition, could also be a fouled O2 sensor, due to running a catless downpipe.
    Feb 13 2015
    VA
    The codes are the source of your issue. Your JB1 doesn't turn off the rear O2 like a tune for a catless downpipe would, it just fools sensors into providing more boost. You need to resolve the codes, whether that be by flashing the car with a tune that turns off the O2, installing a spacer/fouler on the sensor to make it not throw a code, or putting the stock or another catted downpipe back on the car.
    2015 S3 - Revo Tuned
    2016 SQ5
    2008 F350 - Pistons/Cam/Studded/Deleted/Single Turbo
    2010 GT500 - Twin Turbo
    Sep 29 2007
    Clarkston, MI
    Quote Originally Posted by S3Danny View Post
    its worked fine for over 6 months like this so I highly doubt its the source of the problems. I have a spacer on the sensor, it doesnt throw the code all the time it happens once in a while though.
    2000 911 C2
    Feb 13 2015
    VA
    Disconnect the battery for 15-20 minutes and I bet it runs fine afterwards.
    2016 SQ5
    Sep 29 2007
    Clarkston, MI
    thanks man you were right, just slapped new ones in and it runs perfectly again
    106 bucks including shipping from genuineaudiparts
    2000 911 C2
    May 16 2015
    Awesome man! Glad I could help
    AKA: NathanMansoor
    Aug 08 2016
    Wouldn't this have been covered under warranty?
    Sep 29 2007
    Clarkston, MI
    probably but for a 100 bucks it was not worth my time lol
    2000 911 C2
    Aug 08 2016
    Lol ok then
    Sent from my SM-G930W8 using Audizine mobile app
