So I have an 01 Allroad that has a rather annoying issue... none of the fans will work. Already read through the archives, nothing has helped. Replaced the fan control module, jumped the pins on the lower coolant line fan sensor, etc. Fans all work when connected to the battery. I read somewhere that the after run thermal switch plays a part, any truth to that? I deleted the after run pump during my build so could I delete the sensor and jump it out if it plays a role in this and has no other impact? Are there any other relays or fuses? Things to test?
Thanks!!
