Results 1 to 11 of 11
    Oct 11 2016
    Massachusets
    Question Best b8 a4 performance upgrades for $1000 total?
    I recently purchased a 2011 Audi a4 premium plus sedan with 102k miles and I was wondering what performance upgrades should I do first with a total budget of around $1000. I definitely want to get the APR stage 2 tune.
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Always upgrade the driver first. Car control clinics. Club track events, etc.
    Established Member Two Rings Hybrid81's Avatar
    Sep 18 2016
    Delaware
    102k
    I'd check the service records first. Take your $1000 and put it towards any crucial maintenance that may be overdue.
    Read the forums to find out what typically requires replacement around that mileage.
    That could take a bit or all of your 1k, but it'll be worth the peace of mind.
    Brilliant Black A4 Sline | 6MT | APR Stage 2 | Escort 9500xi | JHM Short Shift/BFI | CTS K04/Unitronic IC Next
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Tune and downpipe (or test pipe).
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 10 2016
    North Carolina
    Exactly what hybrid said. I recently got a 2011 with similar miles. Was hit with over 4-5k worth of repair and the car had a good maintenance history. Think my situation may be a little extreme (timing chain, fuel pump, battery, and more all needed repair a few weeks-months after purchase), but also just got hit with oil consumption despite the car already having pt 1 done without AoA or the dealership covering any of it. Might wanna wait it out for a few months and see what could come up.
    Oct 11 2016
    Massachusets
    The 1k budget is after maintenance. Im thinking ill get a gfb dv+, high flow cat, apr stage 2, and maybe a sway bar.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Not for $1000 you won't....
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Hunter2011 View Post
    You obviously haven't done your research on these prices... You just posted a question and waited for people to feed you info...
    Senior Member Three Rings petraman's Avatar
    Apr 26 2016
    Columbus, OH
    You could probably do stage 2+HFC with APR's sale going on.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    102K on your car? I would spend that money on getting the timing chain and tensioner replaced, then mod.
    Stage 1 more than you RS3
    Veteran Member Four Rings quattroforlife's Avatar
    May 24 2012
    2016 Tundra
    Southern CA
    Even though you might think thats after maintenance, I would get all maintenance done first, drive for a bit, then determine if you still want the 1000 bucks of mods. Maintenance might be more than you're assuming.
    Zach
    2016 Toyota Tundra // Methods | C4 Fabrication | Warn | Icon | Toyo | Baja Designs
    Gone, but not forgotten:
    2020 C63S Coupe // Nemesis plate frame
    2000 Toyota Land Cruiser
    B8 A4 // Just about everything
