Results 1 to 7 of 7
    Oct 02 2016
    solihull uk
    Rear wheel spacer dilemma
    Hi all
    I have an Audi a5 2.0 tfsi 2010 plate.
    I have measured and need 15mm rear wheel spacers to get the nice look many of you have. The problem I have is finding some hubcentric ones to fit as the hub length is so long. I have tried some (cheap) spacers that were supposed to fit for the car and the centre bore length was too shallow which left the spacer about 2mm short of seating flush against the hub. Hope this is making sense so basically the hub length hit the chamfer inside the spacer bore before it could sit flush.
    Has anyone had this problem and know of any 15mm spacers that will definitely fit? Or another way around this?
    Thanks
    Veteran Member Three Rings Schrubbe8210's Avatar
    Jun 16 2012
    1997 B5 A4 track car, 2017 Q7 Prem Plus
    Elm Grove, WI
    42 draft designs. best wheel spacers ever. hub centric, and wheel centric!
    Mar 21 2015
    H&R
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Anyone know what the center bore is on RS5s?
    57.1?
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Jul 07 2014
    Calgary, AB, Canada
    Quote Originally Posted by s vier View Post
    57.1?
    Should be 66.6
    2013 S5 6MT Phantom Black Pearl, Unitronics Stage 2+, AWE Touring /w res downpipes, KW V1, Eurocode Intake
    Oct 02 2016
    solihull uk
    Thanks for replys. Size is 66.56 or 66.6 which some Mercedes also use. I will speak to H&R as this seems a popular choice for the A5.
    Established Member Two Rings stefdds's Avatar
    Sep 30 2014
    2002 Subaru WRX (many rally mods, 300hp)
    Milwaukee, Wisconsin USA
    Hi DW, Hartmann wheels is a good source as well, as they can set you up with the proper length bolts for the spacer as well. For example, That is, the spacer gets bolted to the hub, then the wheel uses your stock length lug bolts. Have fun as this is a really great way to refine the look of your car. Stefan
