Hi all,
I Purchased a 2004 s4 with 92k miles on it that had timing issues, it was something i always wanted to do and fix myself, and i did i changed all the tensioners along with the mechanical adjusters and the motor could not sound any better, but i am having a bit of an issues here, when i am in neutral and i press the accelerator the response is great but when i put it in gear i only get 1/4 of the way down with good response and after i press my foot all the way down i get very very very little response i see the RPM going up at a ridiculous slow rate, there is no missfire codes or anything, but i do get a code P2127-Throttle ?Pedal Position Sensor / Switch E Curicuit Low, i bough a new pedal senor and i still have the exact same issue, if anyone has had this issue before please do help, after all the work i put into it i really want to drive this monster.
Thank you,
Bob
