I have turned the engine over by hand with a socket on the crank, everything feels fine, no interference, and I know the cams in each head were aligned after i replaced the cam chain tensioner gaskets, just wondering if there is any way one cam could skip a tooth as i'm turning engine by hand. I didn't hear of feel anything odd, Im probably overthinking it, I'm pretty sure it is fine, just wondering if a scan can verify before i fire up the engine. Maybe I should just start it, if i can turn it over by hand, it should be fine, right? I've just never worked on a car with cam chain tensioners before, scared that since they were compressed to change their gaskets, maybe there is some special procedure to re-establish oil pressure and prevent skipping? I should have left the valve covers off until the timing belt job was done and verified, but I didn't. If they were aligned after I bolted down the tensioners, is there any chance they could then get off from rotating the crank? Seems unlikely... but any feedback is appreciated...
