Results 1 to 20 of 20
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Clicking noises go up slightly inclined driveways..SOLVED BY DEALER
    A while ago I posted about clicking noise turning in to driveway, noise coming from drives side under hood. Brought car into dealer for ECM UPDATE , AND the noise problem. Fortunetly there is a similar drive way turning into dealership. THEY HEARD IT, each time they drove car Turning into. Drive way( no famous can not replicate ) . SA even commented , at least we hear it . I went on a test drive with the Senior Tech, he thought it had something to do with uneven load of suspension. Tried bunch of things to duplicate in service bay. Suspension components where tightened. He spent hours. Finally assistant shop foreman drove car. Then he drove it with hood. UNLATCHED Noise was gone! They readjusted hood and put felt tape on the four bumper locations on hood. sound is gone. They did this on a Saturday despite not a day for extended projects . Hoffman audi east hartford ,ct tech was AJ, FORGOT assistant shop formans name now. I today dealership GM & SA how pleased I was.
    The tech loved my car,and the grey & black seats. He thought car was amazing, a real sleeper, maybe that is why he was so dedicated.He probably will not get paid for all the time he spent, but was just as glad as I was that they could fix it.
    ECM update was also done. No ill effects noticed, but it is still early to notice. Tried to update original thread, but I could not find it.a
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    Good deal, and to find your thread, click on your name and you can find posts you have started or participated in.
    Aug 22 2014
    bloomfield,ct
    now there is a new noise , clicking noise from back of car when staring from stop, it is intermittent. Front noises where solved by adjusting hood and putting felt tape on ends on the hood adjustment bumpers. It hear on click from rear now , intermittent. Any ideas. Car going to dealer, but afraid I will get" can not replicate"
    Senior Member Three Rings Victor Newman's Avatar
    Oct 26 2014
    NC
    the trunk... duh
    2010 S4 / 6MSG / Sport Diff / Alcantara Interior / StopTech 380mm BBK / Hawk HP+ / Castrol SRF / SRP Pedals / H&R Super Sport / VMR V710
    Aug 22 2014
    bloomfield,ct
    [QUOTE=Victor Newman;11972728]the trunk... duh[/QUOTE) I emptied trunk out, nothing moving in there.
    Jun 18 2009
    Phoenix, AZ
    Interesting, I have the same noise happening under the same circumstances, took it in to do the recall update and had them investigate the noise while it was in. They couldn't reproduce it, but I hear it every day. I'll have to check out my hood, thanks!
    2017 Camaro SS 1LE
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    I have the exact same noise and have driven up the incline to my garage with the hood unlatched before and it alleviates the noise. Glad I'm not the only one, will have them look at it next time I'm in. Thanks.
    Oct 26 2014
    NC
    Quote Originally Posted by jygesq View Post
    just messin with ya man. good luck getting it worked out
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by FWP! View Post
    They adjusted good bumpers and put felt tape on them
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by jl87 View Post
    Well I am glad to know I was not the only one. Now if they can find noise from rear.
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    I'm having this clicking now when I go up the driveway. Could you take pics of where the felt tape was placed?
    Aug 22 2014
    bloomfield,ct
    a piece of felt tape was placed on the tips of the four plastic bumpers that are attached to the hood/ I have no camera capability . You should see them easily
    Aug 22 2014
    bloomfield,ct
    [QUOTE=jygesq;11973263]Well I am glad to know I was not the only one. Now if they can find noise from rear.[/QUOTE dealer actually found noise in rear, when car goes from stop and hit 7 mph, there is a click coming from the rear, it is the actuation of the electronic motor mounts!
    Senior Member Two Rings osspasha's Avatar
    Sep 18 2013
    [QUOTE=jygesq;11995524]
    I have the same exact issue, fixed with the same way, now i have the same issue in the rear. can you provide more details on "the actuation of the electronic motor mounts"?
    thanks
    2013 S4 B8.5
    Don't let fear and common sense stop you
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Had the same noise, fixed the same way by local audi dealer. This really made me question the build quality of audis..My old subaru never had such issue.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Aug 22 2014
    bloomfield,ct
    At exactly 7mph starting from stop, a relay or solinoid clicks activating the electronic engine mounts. I hear a single click from rear of car. Dealer tracked down the noise after hearing it on test drive. Put car on lift and at exactly 7 mph a single click was heard . On the road I hear that single click on start up from stop. But not on every time car stops and goes. Dealer duplicated the noise with an other S4,that was in for repair. Dealer considered it normal. Another owner of a 2015,s4' had same experience. Very faint click, but I have to get used to it. Nothing that will damage car. I asked service manager to contact audi technical rep. If enough of us hear the noise maybe audi will do something about it.the noise a single click leads me to believe it is a relay or module in the fuse/ relay section in the right rear quarter panel behind the little cargo net I doubt my dealer Service manager will really do anything more, but I will call audi directly if I do not hear from him. I think it is a relay/ module that needs better sound isolation.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Put any exhaust on it and you'll never hear any of that stuff again. ;)
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Aug 22 2014
    bloomfield,ct
    Quote Originally Posted by Vogz View Post
    that is probably why this comes up so infrequently,as most poster here have exhausts that mask any minute noise.
    Jul 25 2010
    WI/IL
    Thanks to the OP for posting this, this resolved my front end noise I assumed was suspension clunk. Even with exhaust it was very noticeable when pulling onto uneven surfaces at slow speeds.
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    This describes it for me. I have not, and I do not plan to have Audi look into this. With music on I rarely hear it.
    There are all sorts of noises in this car. You can hear the shift interlock solenoid if you turn off the music, put your car in park, and then just tap the brake. Listen towards the center console shifter. You can feel it in your hand as well.
