VCDS Log
- Is 17.3 to much total timing pull?
- I just filled up again and added 3 gallons of E85 (most likely E70-E75 this time of year) along with 16.5 Gallons of 93 octane. Should timing pull in cylinders go down (currently seeing 6.4 degrees with 93 octane)? I wont have a chance for a few more days to test but just curios. I read this thread which rocks, and I'm now trying to tweak and play with different configs which best run on my car. Seems with this combo I'm at 94.8 octane and 20% ethanol.
- What are people seeing when blending a few gallons of E85 in terms of total Actual PSI? I'm currently seeing a max of 15.5 psi on 100% 93 octane fuel along with 93 octane map. Hoping I gain another 1-2 psi with the blend I have in the tank now on the 93 pump file.
- Does GIAC have a specific flash for Dual Pulley out that goes with either 179 or larger crank pulley's?
If I get an upgraded crank pulley, I'd get the AWE Tuning ColdFront System. In looking at the AWE website, see this product which is compatible for the 2016 Q5. Unfortunately only the Heat Exchanger seems compatible with the Q5 as they don't list a Reservoir or Coolant Pump.
