Results 1 to 6 of 6
    Sep 25 2011
    Ohio
    walbro 450 install help
    so i got a walbro pump, started assembling it to the stock basket, and the plastic in-tank feed tube between the pump and the hat doesn't fit over the outlet on the walbro pump, i tried jamming it over it and i split the hose. now my question is, what type of hose is this so i can buy it...it's obviously not rubber fuel line. Probably not vinyl either i would think if it was it would get hard and break. Has anyone else been able to get the stock tube over the walbro pump?
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    What I did was take a heat gun and heat the tube up. This will expand it enough so you can wiggle the tube on or off the pump.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    It's PTFE fuelline. Submersible rubber hose will work as well
    Sep 25 2011
    Ohio
    Quote Originally Posted by cinimod25461 View Post
    I wish i thought of that first.
    Quote Originally Posted by Zba View Post
    Thank you sir, now i know what to tell the guy at autozone instead of just saying 'fuel line'
    Nov 05 2009
    Denver
    It has to be submersible though. Lots of counter guys don't know the difference.
    Sep 25 2011
    Ohio
    Whats an obvious way to spot the difference.
