Results 1 to 28 of 28
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    Question RS5 brake service- Dealer cost
    Hi Everyone:
    Rather than add to an old post that morphed into a different discussion I decided to start a new thread.
    At 28K miles my RS5 needs new brakes. The car vibrates when I brake at highway speeds so I am going to need new rotors. If I source the parts from ECS and have an independent do the labor it will cost me about $2100. The dealer has quoted me $2500 for the whole thing. I am not interested in aftermarket parts at this stage; I like the ECS wave rotors but they do not have one for the rears so I am not too keen on the front rotors not matching the rear one.
    Have any of you had the brakes serviced by the dealer? If so how much have you paid?
    Thanks
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Do not get OEM rotors - I'm on my third set at 25k miles and they just started vibrating again.
    I'm about to switch to ECS
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Four Rings dazed1's Avatar
    Jan 18 2013
    SF Bay Area
    ECS in front, OEM in the rear. I run that setup on track, never had an issue with the rears.
    Fronts are too soft for track use. I never had any vibration or anything while I was on the OEM's. If you go to an independent shop, go to Griffin. Become a member of the Audi Club (PM me and I can help). You'll also get a 10% discount. Have them bed the brakes in really well. Its usually Nate or Gabe who work on my car.
    Since you're using it on street only, get the ECS front, OEM rear. Stoptech 309 Pads for the front. Can stick to stoptech or to OEM's for the rear. The stoptech pads for the front are about 250'ish (both sides), compared to about 400 for OEM.
    Jul 10 2014
    SF Bay Area
    Quote Originally Posted by chrissurfr View Post
    Thanks Chris:
    Mine lasted 28K miles. When are you going to change?
    Jul 10 2014
    SF Bay Area
    Quote Originally Posted by dazed1 View Post
    Can you do me a huge favor and PM me a side view of your car? I'm concerned about the contrast between the rear OEM and the ECS front rotors.
    Senior Member Three Rings wildtouch83's Avatar
    Mar 04 2013
    United States
    Quote Originally Posted by namvar View Post
    I, too, am running ECS rotors up front and OEM in the rear. You don't have anything to be concerned about.
    I opted for EBC red stuff pads on the front instead of the Stop Tech pads.
    Also, for what it's worth, I had my dealership install the aftermarket parts. They charged me 2 hours labor to do so. All in all, I think I was around $1500 total for parts and labor.
    2018 Nardo Gray TT RS - SOLD
    2018 Manhattan Gray Q5
    2006 A4 Avant - RIP
    2013 Phantom Black RS5 - SOLD
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Girodisc rotors will be my pick...
    http://www.girodisc.com/Girodisc-Fro...S5_p_6542.html
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Jul 10 2014
    SF Bay Area
    thanks. I really like the look of the wave rotors. Any other suggestions?
    Apr 26 2005
    Houston
    Thanks Chris:
    In the upcoming weeks when I have the time. The car is at Audi for some engine bay rattles but as soon as I have it back I'll swap out the fronts to other the 380mm ECS upgrade kit or the 365 ECS rotors
    These save 1 pound each
    https://www.ecstuning.com/Audi-B8_RS...ors/ES2785596/
    380mm upgrade
    https://www.ecstuning.com/b-ecs-part...FYMlgQodxIkM7w
    • eCode headlights
    • Eventuri intake
    Jul 10 2014
    SF Bay Area
    I wish they had replacements for the rears that matched these
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by adbender View Post
    How do you mount these 380mm rotors while the stock ones are 365mm?
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Established Member Two Rings PLAYRZ's Avatar
    Oct 22 2014
    RS5 Coupe (B8.5), TT Coupe (FV)
    Australia
    I'm sure I read somewhere in a post from Jason @ ECS that they were developing matching rear Tru-Float wave style rotors for the RS5. Might be worth reaching out to them to see how far away the release is?
    KW | Capristo | BC Forged | 3M | ECS | K&N | SPC | 034 Motorsport
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Not to threadjack but since original question has been answered can you guys comment a bit more on your pad of preference or experience with different pads?
    2019 QUANTUM GRAY S4
    Stock
    Prev
    2015 SUZUKA GRAYRS5
    2013 SUZUKA GRAY RS5
    2015 MYTHOS BLACK S4
    2008 AVUS RS4
    2004IMOLA YELLOWS4
    Feb 04 2010
    Ottawa, Canada
    Quote Originally Posted by yjypm View Post
    "Caliper Bracket For RS5 380mm BBK" listed on the BOM at the bottom
    now I'm curious if 19" would clear them for winter!
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance (on order)
    Jul 10 2014
    SF Bay Area
    ummmmmmmm. Although I have gotten some great advice, it seems that no one has had their brakes serviced by the dealer. I am still waiting (hoping) for some baseline dealer cost.
    Oct 08 2015
    Quote Originally Posted by Runge View Post
    Is there anyway to purchase the brackets and rotors alone? I have new pads and already have ss lines, there's no point to buy the entire kit.
    Current: '18 M3 ZCP
    May 11 2016
    Mobile, AL
    I haven't had the service done yet, but last month I was quoted 2200 for fronts, 1800 for rears for my 2014 rs5
    Apr 26 2005
    Houston
    Seriously, don't get the OEM rotors and pads unless you want to risk warping. You dodged a bullet so far...
    • eCode headlights
    • Eventuri intake
    Jul 10 2014
    SF Bay Area
    Thanks Chris. Not ignoring your advice
    Jun 13 2009
    19" will clear 380mm rotor for sure. S4 guys use them all the time.
    18" is a no go for all bu the most specific wheels.
    2023 Q5 2.0 Technik
    Mar 04 2013
    United States
    Can't find my quote from before but it was around $2300 for the dealer to replace fronts with OE parts.
    2006 A4 Avant - RIP
    Jan 18 2013
    SF Bay Area
    I have. The cost of just the rotors was about 1500 + labor + pads (OEM), came to about 2500-2700. so 2100 for the whole thing is not bad.
    Again, go with ECS stock sized and shaped rotors. Not the bigger size, not the round, but wavy ones. That way in the future, if you need replacements, you can buy just the ring for much much cheaper.
    Jul 10 2014
    SF Bay Area
    thanks!
    Oct 08 2015
    I don't see ecs selling rotor rings...
    Current: '18 M3 ZCP
    Jan 18 2013
    SF Bay Area
    Call them :)
    - - - Updated - - -
    thanks!
    I'll have my car tomorrow. If you like, you're welcome to see the rotors in person.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    As far as I know ECS doesn't sell just the rings, but they give a discount on a new set to the original owner. My front pads are coming up for replacement soon, they are down to 30%, but I think the rotors might be good for another set, so I probably won't be able to take them up on their discount, but if I end up getting new rotors, I can let you know about the cost. You can hit me up, too, if you want to see the rotors in person. I think they look awesome, much better than the OEMs and it doesn't bother me that the rear looks different. The rear caliper is different anyway and if you had gotten the OEM carbon ceramic fronts, they would be different, too. I think having different rotors on the front visually underscores that they are really doing most of the work.
    Here's a close-up. Don't have a side shot that shows front and rear. As for the cost, I had Griffin in Berkeley install mine, along with SS lines and better fluid. With parts and labor it was about $1500 for the front. I put on matching Hawk pads on the rear a couple of thousand miles later. Still have the original rear rotors. The rear really doesn't do much work. My rear pads still have more than 75% left. I do recommend you put matching pads front and rear. I noticed that the brake balance was off with Hawks on the front and OEM pads on the rear, not to mention that the front wheels stayed cleaner a lot longer while the rears turned black within a few days.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Established Member Two Rings djthart's Avatar
    Mar 22 2013
    2014 Audi RS7 Panther Black, 2018 Honda Accord Sportm Black-Sold, 2010 Audi S5 Brilliant Black-Sold,
    Houston
    Had this same issue with mine, never got it done because I traded it in, but my plan was to go, factory rotors hawk hps pads all around. I didn't want mis-matched rotors either.
    Sent from my LG-H910 using Audizine mobile app
    Jul 10 2014
    SF Bay Area
    Angry ECS rear Rotors
    ECS just announced rear rotors matching their front one. If only they had done so a week ago.
