Results 1 to 6 of 6
    Aug 14 2016
    Texas
    Bilstein coilovers question
    So I've had the B16 setup on my car for a few weeks now and I'm starting to hear a clunking noise coming from the front struts. Any ideas to how to fix this? I'm thinking it's the top nut on the struts but I tightened them myself and thought they were tight enough. Suggestions?
    Aug 14 2016
    Texas
    Bump
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Tight enough or correctly torqued?
    Who installed them originally? Were they assembled correctly?
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    I would check the top nut first.
    9 times out of 10 that is the issue.
    Thanks,
    Alex.
    Veteran Member Three Rings Brick Oven's Avatar
    Nov 03 2010
    SF CA
    I think there are a few older threads regarding this issue with the pss10's. Never had the same trouble with mine so I'm afraid I'm not much help here. Good luck!
    2013 Daytona B8.5 S5 : PP : Diff : Magma : DSG : Carbon : B&O ::: HRE P47SC 20x9.5 et20f et15r brushed titanium : Michelin PSS 265/30 : Bilstien PSS10 : SPC Control Arms : Eurocode Alu Kreuz : OEM Ecodes : OEM BO Grille BUILD THREAD: http://www.audizine.com/forum/showth...40#post7874340
    Aug 14 2016
    Texas
    I installed them myself and pretty sure they are installed correctly as this isn't my first coilover installation. But I had to tighten the top nut by hand. Should I try and hit it with a impact? It's hard to get a torque wrench to check the lbs
    - - - Updated - - -
    That being said, do u know the torque specs?
