So your pump is still working. Being on a lot probably means that it's trying to get all 4 bags filled but it will cycle on and off until it shuts off and throws a light if there is a fault. Is there any light on for the air suspension?
Did you spray the side that sits lower with soapy water to make sure that it's not leaking?
Undo the cover to the compressor and do the same thing, spray the air line connections.
Check the ride height sensor on that side? Junk/water will do some damage. Some you don't have a vagcom yet you can simply unplug/plug to see if it clears the issue.
Sent from my Nexus 7 using
Audizine mobile app
