Results 1 to 7 of 7
Thread: Fan issue
    Veteran Member Three Rings luvsspeed's Avatar
    May 13 2007
    04 S4
    North Carolina
    Fan issue
    I seen similar post like this in the past. I went to start my car yesterday and my battery was kinda weak, from it sitting almost a week. I had been using to charge cell phone batteries due to hurricane in the south east. I had been starting car during that time with no issues, also car it parked in car port so it did not see the rain. I go to start it last night and it was kinda a weak start but it started. I let the car run for about 15mins and I turn it off, but fan is still running. Every time I would start it after that sat radio would reset. I have seen most have replaced the fan control module and that has solved the issue. Would that be the likely cause of issue or could it be the battery due to the low voltage. I have the battery on the charger, but have not checked for codes as of yet. Also battery is at minimum 9yrs old. I would rather replace the battery over module due to cost, but I want to replace the right thing the first time.
    Thanks in advance.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Charge the battery, test it if the battery is good, then scan the ecu with vcds and youll have the answer.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Have you ever checked your cowel drains?
    Common problem is the 2 drains in the cowel area, 1 under battery and 1 under the booster and ECU plug up slowing the water draining, if you get a really big dump of rain the cowel can fill. If the water gets high enough it can enter your ECU
    Apr 08 2008
    New Westminster BC
    Dam phone....
    If water gets into the ECU there are several relays right in the bottom that can rust and act up, common indicator that 219 relay sticks on and causes the fan to run on after key turned off.
    If control module is fucked the fans won't run at all.
    With your battery problems I'd charge your battery right up then run car till fans come on and then shut it off, and see how long it takes for the fans to shut off. If they are running on that could be draining you battery. You could have a relay that is on its way out.
    May 13 2007
    04 S4
    North Carolina
    Thanks guys. I got off of work late and did not have a chance to check anything yet. I will check out the things that were suggested and report back with what I find tomorrow.
    May 13 2007
    04 S4
    North Carolina
    Checked under ecu and it was clean as can be and relays were like new. Ran vcds and found the problem.
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 A HW: 8E0 907 560
    Component: 4.2L V8/5V G 0020
    Revision: 00000000 Serial number: AUZ6Z0C0181129
    Coding: 0007711
    Shop #: WSC 65728 1018 854933
    VCID: 234580C4E11EBC5A93-5140
    2 Faults Found:
    18068 - Coolant Fan Control 1
    P1660 - 002 - Short to Ground
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    Readiness: 0110 1101
    Traction control light won't go off as well. I didn't have that issue before I disconnected the battery and found this new code as well. Would the car have to be driven to clear thing?
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 Q
    Component: ABS/ESP allrad 3032
    Coding: 04595
    Shop #: WSC 08154
    VCID: 36634990128C39F244-5124
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    May 13 2007
    04 S4
    North Carolina
    I would like to think this is the correct one. Can anyone confirm this?
    https://www.ecstuning.com/Audi-B6_S4.../Fan/ES441173/
