    Jul 15 2014
    Cape Breton Island
    Power steering rack same as A4
    I have a B6 S4 with a leaking rack. I was looking to purchase a rack from a company that says it will fit my S4 from a A4 B6.
    Are they the same? Just wanted to make sure before I pulled the trigger.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    No they are not. I think technically it would work but I'm not sure if it would cause any long term issues. From what I've heard the S4 rack has a tighter turning radius. I actually put in an A4 rack before and it looks different. It still bolts in and everything though, I did drive a few hundred miles with it actually before some (I think unrelated) issues came up..
    Edit: Found my threads.
    http://www.audizine.com/forum/showth...e-Rod-End-What
    http://www.audizine.com/forum/showth...is-my-new-rack
    Here are some pics:
    http://imgur.com/gallery/fzm60
    But yeah I they are different part numbers. I got my (final) replacement rack from FCP Euro, was like $750 after core return.. lifetime warranty and it was in great shape. I changed my rack twice in the span of a week earlier this year so if you run into any issue shoot me a PM and I can try and help. The PN stamped on my rack from my 2005 S4 Sedan (build date 11/2004, last 6 of VIN is 107640) is: 8E1422105B
    This thread is also very helpful:
    http://www.audizine.com/forum/showthread.php/467565-Power-Steering-Rack-Replacement-%E2%80%94-B6-B7-A4-S4
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jan 29 2010
    north ga
    I thought the only difference was S4's came with servotronic, and most all A4's did not.
    I also just put in a new steering rack (however it was in my A4) and yes, it's quite a fucking job to do
    Veteran Member Three Rings outsider6661's Avatar
    Jul 02 2007
    2008 RS4, 2016 S5 Black Optics
    Markham Ontario, Canada
    Rack ratios are different
    Sent from my SM-G935W8 using Tapatalk
    Jul 15 2014
    Cape Breton Island
    Thanks everyone !
