Originally Posted by
mlavelle92
DO NOT REMOVE THE HANGERS, JUST REMOVE THE EXHAUST FROM THE HANGAR. Pretty sure one of the passenger side hangars also holds up a corner of the gas tank and it was a PITA to push back up and hold in place with a full tank.
Unfortunately saw this too late, and yes the passenger side also serves as support for the fuel tank. what at PITA. As I was working by myself, the only way I was able to get this one back on was to use a jack to move up and support the tank while I got the bolt started.
I had to cut the sleeve clamps on the downpipe - mid muffler section, as the nuts just started spinning. Besides that was pretty strait forward, took a little bit of time to adjust to get everything level, strait and equally spaced in the rear valence. I did not use any "heat temp exhaust paste" FWIW. No apparent leaks as of yet, keeping fingers crossed.
let me just say, this setup: stock down pipes + AWE touring edition catback is one sickk setup!! I absolutely love it. Sounds exotic/deep throaty/mean when you want it to be, and quite when just daily driving arounds. This is the way this car should sound from the factory IMO!! Highly recommended!!
