I have done a bunch of research, and have done all the troubleshooting I can think of, but would like to ask for some more help. I recently replaced pads and rotors (Duralast Gold DG840 pads, Raybestos 980001R rotors) on the front. The driver's side is working perfectly. The passenger side drags lightly - I can't feel it while driving, but the wheel feels noticeable warmer after driving, and I boiled some brake grease and got a little smoke after driving ~1 hr on back roads. Lifting the front, the wheel can still be spun by hand relatively easily, but with noticeable resistance. The pads are clearly in contact with the rotor - the contact seems to be equal on the inner and outer pad too. Here's everything I have done/checked:
- Wire brushed and re-greased the caliper pins; they seemed to be in good condition
- Cleaned caliper bracket with wire wheel where the pads slide (there was some rust) and re-greased
- The caliper piston still retracts smoothly with a c-clamp
- The brake lines seem to all be in good condition
- No pressure buildup when opening the bleeder when the brakes are hot
- No other brakes have symptoms
- The rubbing is uniform as I spin the wheel
- I don't know when the fluid was last changed, but it looks fine when bleeding
- When driving, braking is smooth without any pulling
Does smooth retraction of the caliper piston necessarily mean that the caliper is good, or can it still be the problem, even if it feels normal? Are there any other parts besides the guide pins and pad carrier that ought to be clean/inspected/regreased? Are there any installation issues which could cause rubbing?
I am not sure if the dragging is constant, or increases with use/heat.
