Results 1 to 21 of 21
    Jul 12 2015
    Auckland, NZ
    Just broken down. What do you guys think it could be?
    Hey all,
    Car has just broken down on the side of the road. Engine was misfiring and very jittery all of a sudden, CEL was flashing. Tow truck has just been sent out.
    My first guess would possibly be a bad spark plug. What do you guys think?
    2013 B8.5 S5 3.0T Monsoon Gray | Stage 2 ECU+TCU. APR Pulley upgrade
    Jan 28 2006
    connecticut
    Sounds like bad coil pack
    Jul 12 2015
    Auckland, NZ
    Thanks. How costly do you think for a new one?
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by EMC2 View Post
    $30
    Stage 1 more than you RS3
    Jan 13 2014
    nyc
    I would recommend you buy 4 of the r8 red tops from amazon for 90 bucks. Can't beat the price or the quality.
    Aug 08 2016
    Waco, TX
    Quote Originally Posted by nycaudi View Post
    Good idea. I did this as preventative maintenance on my 2012.
    The PCV diaphragm tearing will also cause the engine to feel like it is misfiring and will generate a CEL, but it also usually results in the "Oil Pressure is too low, please shut down engine" warning.
    2012 A4 S-Line 2.0T Quattro w/6MT; APR Stage II; APR Downpipe; APR Turbo Muffler Delete; R8 Coils; NGK plugs; APR Intercooler; P3 Vent Gauge; Full mandrel custom exhaust; JHM short shifter; Luft-Technik Intake System; GFB Diverter Valve Upgrade; Drilled & Slotted Adams' Rotors w/StopTech Pads & Braided Lines; Bilstein OE Sport Struts/Shocks
    Established Member Two Rings PurdueB8A4's Avatar
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Do you happen to have a link?? There are multiple vendors selling these, I'd obviously be willing to spend a few $$ more to ensure the best quality.
    2009 Quartz Gray Metallic Audi A4 Prestige
    aFe | Akebono | APR
    Jan 13 2014
    nyc
    Yeah of course. It's in my amazon history
    https://www.amazon.com/Genuine-Volks...rds=06E905115E
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    at what miles should i replace the stock ones with these?
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Thank you good sir!
    aFe | Akebono | APR
    Jan 13 2014
    nyc
    Quote Originally Posted by JeriQo View Post
    Well these are a upgrade. id swap em and throw in new plugs as well as soon as you get em. Just read some of the reviews on there, lol.
    The regular oems should last for the life of 2 sets of spark plugs. The performance will degrade however after that. My regular oems were still good before i switched to these' so i saved em and put them in genuine VAG boxes that these come in. The 4 regular oems i pulled were at about 20k of usage.
    Just be careful when releasing the harness from the head of the coil....now that its getting colder that plastic becomes very flimsy and is easily broken if youre not careful. I would change em when the motor is still warm so you dont pop a clip by mistake.
    Established Member Two Rings punkalex1's Avatar
    Oct 26 2015
    Orange County CA
    found them on rockauto for $70 :O with the same part # from amazon
    https://www.rockauto.com/en/catalog/...tion+coil,7060
    Jul 12 2015
    Auckland, NZ
    Hey guys. Just an update from the garage. One of the coils had gone. He wants to charge me NZ $450 for a diagnostic scan and new coil oh well, guess it is a saturday after all.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / B7 S4 Avant 6MT / Subaru Outback Limited
    Did I read that correctly - $450 for a scan and a new coil pack??
    Cheers,
    Ry-man
    Jul 12 2015
    Auckland, NZ
    You sure did. Well that's New Zealand for ya. Anyway, thanks ncyaudi, I've ordered 4 of those. Should be here next month!
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    $450?!?! I need to open up an ignition coil shop in NZ!
    "Diagnostics" for an ignition coil is such a load of shit its incredible.
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    OP already determine it was not a coil pack (another thread) but only after ordering and replacing changed nothing. For anyone else trouble shooting and coming across this thread, can I recommend just swapping your "bad" coil to another cylinder and seeing if the misfire moves too, if not it's not the coil and you saved yourself some frustration and money by not following the "diagnosis" of someone on the other side of the world saying "sounds like a coilpack".
    My personal agenda for a misfire: swap the coilpack, did the misfire move? No, check the plugs, what do they look like? If they are ok then I start checking the coil pack wiring harness to the suspect cylinder and so on.
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    You had it towed for a misfiring coilpack?
    My current rides...
    Audi
    Jetta
    Jul 12 2015
    Auckland, NZ
    It was completely limp
    Oct 10 2012
    Zionsville and Saint John IN
    Injector?
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Jul 12 2015
    Auckland, NZ
    I hope so. Still at the dealership right now, expecting a phone call soon. Will update thread when I've heard back
