Results 1 to 40 of 60
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    power steering fluid everywhere, lids of steering. no codes
    So tonight. I was driving and all of a sudden my car stopped wanting to steer. Pulled into oreillys, fluid everywhere under my car. Would a bad pump throw a code? Need some help trouble shooting. Otherwise it's going to the local euro fixer upper place.
    04S4
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Notorious trouble on our cars power steering return line.
    http://www.audizine.com/forum/showth...-Steering-Line
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Established Member Two Rings JS4Avant's Avatar
    Dec 01 2014
    2004 dodge 2500
    Battle Ground, Washington
    Not the pump, check your hoses. Mines blew , same thing. Turned out to be the return line.
    Established Member Two Rings Ryanroland's Avatar
    Mar 11 2015
    Honda S2000
    California
    I think I had the same thing a few years ago. Do you have to replace the pump too when it gets air in the system? That's what the indie shop told me and of course the S4 PS pump is 3x the cost of the A4 PS pump
    2006 S4 Brilliant Black | Europaparts cat back exhaust | H&R Springs | B8 S4 19" Peelers | I really need more mods to make this look cool
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by JS4Avant View Post
    So far all i have read is to have a shop do it. I also have 2 front axels B5 perches and 034 motor mounts to do. Should i have them do that at the same time? I am under a tight schedule and i do not have the time to do it myself.
    Jan 09 2013
    ___
    My power steering pump died, which I'm guessing caused a lot of pressure in the system and the pressure release hole on the power steering reservoir cap spewed fluid all over my engine bay. Thankfully my hoses didn't burst, but then again the pump was a major pain in the ass to install. I was driving down the road and all of a sudden a huge billow of steam came from my engine bay and my steering started to get heavy. No error codes at all
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by tmh88 View Post
    Nothing like that. Just lost steering and a trail until i stopped and a pool under me.
    Dec 01 2014
    2004 dodge 2500
    Yea it's a pain in the ass to do it. Most likely it's the one that connects to the rack. Set me back about 400. Had the hose made though for 20 bucks. Oem is way more
    Dec 01 2014
    2004 dodge 2500
    Pump no, hopefully. Depends on how far you ran without fluid. They burn out. There is a process to get the air out, saw it on a diy.
    Oct 05 2015
    Billings, MT
    So i need to dump some in before driving it to the shop? Or is that a waste?
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by Ryanroland View Post
    Never heard of such a thing. You can usually work the steering back and forth to work the air out of the system.
    Sent from my Nexus 7 using Audizine mobile app
    Oct 05 2015
    Billings, MT
    Maybe 2 miles?
    Dec 01 2014
    2004 dodge 2500
    2 miles isn't to bad. Mine was like 20, I had it towed to be safe. Yeah getting the air out was like what allroad said, with cap off the reservoir.
    Oct 05 2015
    Billings, MT
    Is there a fuse for the pump i can pull?
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    My pump lasted through two blown racks and a blown return hose. It should be ok if you don't drive it too far - I didn't drive it at all without any fluid, although it did get some mileage with low fluid.
    I am not sure there is a fuse, I believe it runs off the chain drive on back of motor.
    Hose and rack could be changed in a day if you have the parts available. Definitely a PITA job but the right tools (22mm offset juuuust right) makes it much easier. Hopefully it's just the hose though, even at $110 or so it's much cheaper than a rack lol.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jan 09 2013
    ___
    It's really easy. Top the reservoir off, turn the car on and immediately shut it off. If there's air in the system you'll notice that the fluid level in the reservoir went down a bit. The first time you do it the level might not drop, but if you're sure there's air in the system try it a few more times. Top the reservoir back off and repeat until the fluid level in the reservoir stops going down.
    Oct 05 2015
    Billings, MT
    Well off to the shop. I don't have the time to do it right now with a new born and needing my car for work asap
    Mar 31 2014
    KY
    Gotta pick your battles with a newborn in the mix!! (I had one last year). Can't blame ya for taking it in. Good luck, hopefully the shop gets you sorted out :)
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by badger. View Post
    Thanks and congrats on the baby as well.
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by Terry.Reese View Post
    Let us know how you make out. Good luck
    Oct 05 2015
    Billings, MT
    679.00 that is including the tow.
    Oct 30 2015
    Massachusetts
    What did they say the problem was?
    Oct 05 2015
    Billings, MT
    Low pressure hose. Rack was fine and pump still good. Including checking area looking for leaks.
    Oct 30 2015
    Massachusetts
    Did they include the part number? I've heard of this problem way too many times so I want to see if I can grab it cheap off eBay or something
    Oct 05 2015
    Billings, MT
    I can ask them. The service manager is part of our local FB euro group. I will post here and pm you as well.
    Oct 30 2015
    Massachusetts
    Sent from my Nexus 5 using Tapatalk
    Mar 31 2014
    KY
    Quote Originally Posted by AllroadMass View Post
    I bought mine from genuineaudiparts.com which is where it was cheapest actually. Was $104.. generally floats around $115-120 for the return hose (OEM) from other places:
    P/N 8E1422891AK "Return hose"
    Also here is the banjo bolt and crush washers:
    P/N WHT000507 for "Pressure hose Bolt" (banjo bolt)
    P/N N0138487 for "Steering gear and linkage Pump and hoses Seal Type 1 Type 1" (crush washers)
    Return hose is #12 in pic (note it is drawn in 2 pieces but it is actually just one hose)
    Oct 30 2015
    Massachusetts
    Thanks badger! I thought it was that hose. Same problem last year on my allroad but the leak was in the front of the car. Turn out to be the clamp to the cooler lines.
    The other side connects to the rack correct?
    Oct 30 2015
    Massachusetts
    Why was I so stupid to ask for the part number? I drove home tonight about 8.5 miles without fluid. As soon as I picked up some food and turned onto the on-ramp, it just stop steering. Didn't want to pull over late at night so I drove home. Was that a bad idea?
    Got into my driveway and put some fluid in there and it's bubbling like crazy. Fluid seems to be leaking right at the circular opening of the belly pan near the driver side front wheel. Hoping it's as simple as my wife's allroad. God damn I love this car.
    Nov 13 2011
    b7 s4 avant
    Damn that stupid hose! Mine busted 60 miles from home earlier this year
    I drive a truck now.
    May 18 2012
    2005 S4
    Portland, OR
    Ha, that is the exact hose that blew on mine during a road trip. That was a really fun experience, let me tell you.
    Oct 30 2015
    Massachusetts
    You think it's alright that I drove about 9 miles home without fluid???😑
    Nov 13 2011
    b7 s4 avant
    Honestly, I put about 100 miles with little to no fluid and my pump is still good lol
    Oct 30 2015
    Massachusetts
    Good news! Let's hope I'm as lucky. Should have some time to look at it. Will post what I find.
    Jul 15 2015
    Rochester NY
    Pump is driven by the PTO on the rear of the engine, no electrics involved. Even when the fluid has all run out, the gears inside the pump body still have a coating of oil so "for a while", they'll turn without damage. If you have to drive it with the hose busted, pour a couple of ounces of fluid in the tank just before starting and driving off. That will give the pump a "dose" of lube. You don't really want to drive far, but in an extreme situation, I could see a guy stopping the engine every few miles and pouring a couple more ounces in to relube the pump. Keep your revs as low as possible so that the pump turns as slowly as possible. I would have no concerns personally about driving a few miles from my house to the shop if I pre-dosed the pump. But as always, determine your own level of risk.
    Oct 30 2015
    Massachusetts
    Quote Originally Posted by 924Carrera View Post
    Lol. I swear you're my bad luck...Love you man!
    Oct 30 2015
    Massachusetts
    Just going to leave this here for you 924Carrera...lol
    http://vid36.photobucket.com/albums/...psn6ctpmnr.mp4
    Jul 15 2015
    Rochester NY
    I'm never going to get my wife's car finished, because everytime I see one of these posts, I go out and replace that part so's I don't have to hit it again : ) I'm sure that car will actually end up being brand-new by the time I'm finished.....I'll be single, but it will be done : )
    Oct 30 2015
    Massachusetts
    I try to be proactive too but it's getting crazy with this car, I still dig it though.
    I was able to move the return hose to make sure it was coming from there and sure enough, it is. The return hose is leaking right behind the bottom support bracket of the Aux radiator. Must have been rubbing for the last 12 years and finally decided to let go after I purchased the car and join this forum....can't pinpoint where all my bad luck is coming from. lol
    Dec 01 2014
    2004 dodge 2500
    Stay strong my brahdah.. my s4 been in the shop for the past 3 months. I'm about 8k into it. Bad valve seals. Heads are being rebuilt by JHM at the moment. However, making the best of it by also getting a timing job, clutch kit, oil check valves, valley pan gasket, straight downpipes, and intake spacers. Should be a brand new car by the time I get it back.
