Results 1 to 40 of 72
    Aug 23 2016
    richmond VA
    Ko4 e85 stock long block 11.29 @125
    http://youtu.be/DUkGRVSs5kk
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Nice work
    Aug 23 2016
    richmond VA
    having trouble post a link
    Aug 23 2016
    richmond VA
    Having trouble to post a link
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    moving. well done.
    Nov 05 2009
    Denver
    Beat me to it
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    nice run.
    you see the globe with an infinity symbol on it? approximately ^^^^ there. click that and copy paste. can highlight whatever text you want before you click it to create a custom hyperlink the picture does pictures, the movie reel does movies.
    Aug 23 2016
    richmond VA
    Thank you a much ! I'm new to Audizine but not new for b5 platform
    How I can post time slip ?
    Nov 04 2013
    Palo Alto, CA
    couple ways, if you got a jpg format or one of the other acceptable methods, you can use photobucket.
    if it's not supported there you can make a website on one of the free editors -- but you'll have to hyperlink to the site if it isn't an image file of some sort.
    Aug 23 2016
    richmond VA
    going back this Friday hope get batter times :)
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    That's a really good time. What is your 60ft? Who tuned it?
    Feb 19 2011
    Earth
    Aug 23 2016
    richmond VA
    time slip posted :)
    60 ft is 1.5 remote tuned by solomotorsport
    - - - Updated - - -
    thanks jaychen
    Feb 19 2011
    Earth
    Quote Originally Posted by tasinb5s4 View Post
    time slip posted :)
    - - - Updated - - -
    thanks jaychen
    Great driving.
    Nov 04 2013
    Palo Alto, CA
    That's a really good '60.
    what are you dynoing? It sounded a bit like the 2nd to 3rd might have had 1/10th in it, but hard to tell from just sound. Honestly pretty shocking to see that kind of an ET on 125 mph... well above average driving, very impressed.
    wait a second, did I hear launch control?
    Aug 23 2016
    richmond VA
    yes i got bit more in it -car is not dynod . that night was about 70f night very sticky track i did 3 passes 11.6 11.6 then 11.2 60 ft 1.5 1.6 1.5 car is full weight minus spare tire & rear seats no fog light all rest of the car in one pice no carbon lightweight wheels
    Aug 23 2016
    richmond VA
    yes launch control &NLS NLS lil delay me on 2-3 shift
    Nov 04 2013
    Palo Alto, CA
    ah makes sense. street tires i presume?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    This is getting me amped up . We're still in the low 90s in az and we just lost e85 . Kinda sucks but hopefully e54 will be ok. Seeing this lets me know I can get into the high 11s at least.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    What are your fats?
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    nice launch and shifts.
    one second you're there.....aaaaannnnnddd then you're gone
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Aug 23 2016
    richmond VA
    tires kumho esta 225/40 r18 38 psi track was prepared for big boys didn't even lower pressures she hook all night . but be honest if track prepare shitty you can run slicks still won't hook .
    fat times lol i don't even have vaG-com they don't mean anything to me , i do everything by feel and sound
    when i was on OTS tune with 550 cc injectors car dynode 368 awhp 422awtq on pump gas best run was 12.2 @115 best trap was 117mph at 23psi
    switch injectors to 750 cc SOLOMOTORSPORT SEND ME FLASH LODER WITH E 85 FILE back and forward few times she hit 11.2 @125 gain 1sec & 10mph switching to costume E85
    i will assume car is around 460-480 awhp area 24-25 psi
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    Amazing 60'. What clutch are you running and what was the DA that night at the track?
    May 11 2013
    Nnj
    very cool,i like your attitude. dyno's are great ,but how a car feels and performs in the real world is what matters.
    Aug 23 2016
    richmond VA
    Fidanza flywheel Ringer Racing stage 4 clutch USP metal slave kit ,separate reservoir for clutcht fluid
    Made clutch pedal stop from exhaust hanger and hose clamp
    DA I don't know ! VA is almost on see level but hymidity always very hight
    Sep 07 2012
    Tucson, AZ
    Awesome man great job... That 60' is sexy. What is your suspension setup?
    Feb 19 2011
    Earth
    details on the separate res for the clutch setup?
    Aug 23 2016
    richmond VA
    Suspension drivetrain stock autozone LF axle
    Hyndai accent reservoir from junk yard same line used motul RBF 600 fluid , oem reservoir blocked off . Some resone under hard launches brake reservoir getting pressurized just bit to push clutch pedal down & slip the clutch . After separating it I never had problems
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Very nice times! Good ass driving too!
    Passes me off I was going to run my stage 3 f21 tomorow but just started getting lean codes...... fun fun only have 2 weeks left of the track being open. Hopefully I can take care of it by then
    Aug 25 2013
    great driving
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by jaychen View Post
    moving. well done.
    Sweet! That was an awesome launch!
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Quote Originally Posted by AudiTechS4 View Post
    Wait what? It's always E85-E90 in vegas year round. The fuck?
    Apr 07 2011
    Home of the mighty beaver
    we just lost e85 round here too. nobody sells it now. unless you want to buy drums of it.
    Apr 01 2011
    B5 on jack stands
    charlotte
    That's an awesome run
    I've read ls guys running xylene mixed with the gas
    I don't know if it'll be as good as e85 but it definitely
    raises the octane
    powered by
    Hot Boi parts
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Quote Originally Posted by aysix View Post
    Yep it's some bull shit. Some senator thought it would be a good idea to switch our E85 to flex fuel E54 and so he got a bill to pass that required all E85 pumps to be switched to E54. So far there have still been reports of good power being made on E54 but it's not as resistant to knock as E85 is.
    Jan 29 2009
    Quote Originally Posted by Corradovolksb View Post
    Around E60 will have just about as much knock resistance as 85 actually...
    Nov 04 2013
    Palo Alto, CA
    Hard to keep big oil down. Not surprised, won't be the last state, red states first.
    Aug 23 2016
    richmond VA
    I'm in love with e85 ,That's probably best mod I did , I'm on it 24/7 daily driving it , if I stay out off boost I get about 18-20 mpg
    Just gonna do rods over this winter turn the boost up :)
    Jan 29 2009
    Alcohol fuels really are an amazing mod for FI cars... unlocks so much potential.
