2003 Audi A4 Quattro 1.8t
Drove home from work today, planning on changing the MAF, it had been replaced at 145k with a cheap ebay MAF which was just as bad as the OEM one that failed. So I had ordered an OEM Bosch one, so when I got home installed it. Hoping it was the reason to my low boost conditions. Installed it with battery unhooked, hooked it back up turned on accessories reset ecu with scanner. Turned on car idled good, so I decided to test it out and go for a drive got about 30 seconds in and could tell "didnt punch it yet" boost was being made could here the faint whistle more predominant then before. Then got about half throttle and it got loud, like the turbo was free spinning. Like it was a hose popped off.
Here's what I've checked
-Visually checked boost hoses all are tight?
-Boost leak test No leaks? Wont hold pressure for more then 5 seconds but if I pressure to 15 psi bleeds off in about 5-8 seconds "guess" Hear bubbling coming from valve cover from oil "cap was off" per leak specs
Should mention
Within last 3k miles heres the maintenance I've done
Timing Belt / Tensioner
Head Gasket, Bolts
Intake Gasket
TB Gasket
Water Pump
Brand new Borg Warner K03 turbo
all new gaskets used
Valve cover gaskets
Rear Coolant Flange
All new silicone boost hoses
newer air filter
just changed oil, mobile 1 filter with liqui moly 5w-40
just changed Trans Fluid Filter/ Oil w/ Febi
Fresh coolant with rebuild.
Motor mounts with RS4 style from ecstuning
new rear window regulators both sides
new window switch on drivers door
new snub mount ecs poly
Probably more i forgot , has 150k miles. Pretty much getting it ready for another 100k but keep getting more issues lol. Owned this since 133k and have babied it oil changes every 3k with synthetic and premium filters
Mods
Test pipe
No tune unless it has been by previous owner, never seen it boost over 10/11 psi at max 5th gear on a hill.
Exhaust has a pretty good leak at the entrance to the resonator "waiting to replace" don't think this is relevant.
Sorry for the long post
Throw me any ideas
EDIT
Also put on new air pump plastics hoses 'broke during rebuild' from air box and to air box one.
EDIT #2
Forgot about also changed diverter valve to a brand new audi tt 1.8t valve
And have a new n75 valve coming OEM
