Results 1 to 13 of 13
    Feb 12 2015
    United States
    Installing a used 5f module
    So the recent mmi update (942) did not fix the static/popping sounds coming from the*sound*system in my 2013 A6. Dealer/Audi*is recommending I put in a new 5f*module*@ $3k. I was wondering if I can get a used*module*(4G0-035-74 6-D) do the swap and have the dealer recode. Thoughts? Seems I can get one from a wrecked*Audi*for a lot cheaper but not sure since it was already coded.
    Sent from my Nexus 9 using Tapatalk
    Nov 27 2012
    Houston/Texas
    It is a pretty easy swap. http://m.ebay.com/sch/i.html?_nkw=4G...sqp=4g0035746d
    Sent from my Tapatalk
    2016 S6 | Prestige | Daytona Grey Metallic (APR Stage 1 ECU/TCU, AWE Exhaust, Eurocode Sways and Links)
    Feb 11 2016
    earth
    Quote Originally Posted by kdrfathead View Post
    Do you mind explaining the symptoms in more detail? Is it regardless of source? How loud is it? Thanks!
    Feb 12 2015
    United States
    Quote Originally Posted by Webtoker View Post
    That I understand. It's the vag recoding that I'm not sure of.
    Nov 27 2012
    Houston/Texas
    Ahh, missed that! Why would any coding need to change? Anti-theft?
    Feb 12 2015
    United States
    Quote Originally Posted by fatboydelights View Post
    Any audio source would do it. Nav, sat, FM or Bluetooth. Sounded like someone popping bubble wrap. Loud enough that I had to turn the radio off.
    Feb 12 2015
    United States
    It's also the nav unit. So component protection, etc.
    Apr 18 2016
    2016 RS7 Prestige
    Boston Area
    You would need to have the dealer remove the anti theft protection. The controller is coded to the VIN of the car it was originally installed in. You cannot recode it with VCDS. Only way to do it is through the dealer. I went through the same process for an older D3 A8. Replaced MMI controller myself. Dealer recoded the anti theft protection. Charged me an Hr of labor.
    2016 RS7 / Mythos Black / Comfort Seats / B&O / Layered Alum Trim
    Also in the stable:
    - 2018 GMC Sierra (Daily)
    - 2020 Kia Telluride SX-P (Daily)
    Past: S7, A7, A8, Multiple A6's
    Feb 12 2015
    United States
    Quote Originally Posted by BasicBlack View Post
    Perfect, that's what I figured but wanted confirmation before I picked up a used one. Thanks!!
    Feb 12 2015
    United States
    Dealer confirmed it can be recoded. Grabbed on from a salvage for $2200 less than a new one. See how it goes.
    Thanks again!!
    Apr 18 2016
    2016 RS7 Prestige
    Boston Area
    Best of luck. It should work out just fine.
    Also in the stable:
    Established Member Two Rings jpmorais's Avatar
    Dec 06 2013
    15' A3, 14' S4
    CT USA
    Did it work? I think i need to do the same thing
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Does your car have one of the various Audi sound systems (B&O/Bose etc)?
    You might need to downgrade the firmware on the amp to the original firmware.
